    [Plugin] s4u_Align
    45 Posts 16 Posters 30.7k Views 16 Watching
    • hdpvH Offline
      hdpv
      s4u_Align_v4.0.0
      Set Plane by Object
      Align Axis ,Construction line and BoundingBox.
      Align and Align+Copy(Hold Ctrl).
      http://s3-us-west-2.amazonaws.com/assets.sketchup.com/web/ewh/s3fs-public/s3fs-public/align_0.gif
      s4u_Align_v3.3.0
      Align with BoundingBox
      s4u_AlignTool_v3.1.0 (update 06 April 2015)
      Align in Top ,Front,Left ,Right view...
      s4u_AlignTool_v3.0.2 (update 06 April 2015)
      -Fix toolbar show for Mac
      s4u_AlignTool_v3.0.1 (update 19 Sep 2014)
      -Align with axis ,construction line
      http://sketchucation.com/resources/pluginstore?pln=s4u_aligntool_v1.0.4
      http://extensions.sketchup.com/en/content/s4u-aligntool
      Tutorial video:
      s4u-AlignTool 2.2.0(18 July 2014)
      -Fix error(align edge in group)
      -New feature: Align preselect objects
      s4u-AlignTool 2.1.0(4 July 2014)
      -Fix error
      -The Spanish Language version
      s4u-AlignTool 2.0.3 (1 July 2014)
      -Fix error
      -Hold Ctrl(Alt on Mac)for multi-select -> Double click or Enter for finish.
      -Press Tab, for change align or align+move.
      -Thanks Oxer for update on Mac and translation.
      s4u-AlignTool 2.0.1 (20 June 2014)
      Align selected objects.Press TAB for Align or Align and Move.Press hold Ctrl for multiselect.
      Press UP,DOWN or Right Mouse for opposite Align
      s4u-AlignTool 2.0.0 (10 June 2014)
      • align OUT group,multi-align with press hold Ctrl key.
        s4u_AlignTool_v1.1.0 (25 April 2014)
        -Press UP, DOWN or Right Mouse for Mirror after align face
        s4u_AlignTool_v1.0.4 (18 September 2013)
        -Change key Shift -> TAB ( sometime Zoom+Pan with Shift )
        -Press TAB for Align or Align and Move.
        s4u_AlignTool_v1.0.3
        Update:
        -Fix error Component/Group had scaled
        -Source code
        s4u_AlignTool_v1.0.2 (15 August 2013)
        Update:
        Press Shift for Align or Align and Move.
        Press Ctrl for multiselect.
        Align Edge or Face not in Group(Component)
        s4u_AlignTool_v1.0.1
      Suforyou
      http://www.sketchupforyou.com
      • jolranJ Offline
        jolran
        Hah, exellent!
        I do suspect there exist similar Tools doing something like this, but your plugin look very easy to use and practical. Bravo!
        • hdpvH Offline
          hdpv
          Thanks , Test my plugin ,Jolran
          Suforyou
          • 3 Offline
            3dsmax9
            very nice and useful, thanks.
            • renderizaR Offline
              renderiza
              Excellent plugin thank you for sharing! πŸ‘
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
              • R Do not disturb
                rv1974
                Hi Hdpv!
                Nice script, thanks for sharing!
                Is it possible to add multiple 'Clone aligning' functionality (with say Cnrl key pressed)??
                In that case PRE-selecting the object to be aligned\copied would be more logical.
                • hdpvH Offline
                  hdpv
                  Hi rv1974
                  I've thought about it, I will try,
                  I don't "Pre-Selecting object" because to easily select multiple objects(press enter or spacebar for finish selecting)
                  Suforyou
                  • DETXD Offline
                    DETX
                    Great many thanks.
                    This plug help me very easy align object.
                    Hope more features.
                    • jolranJ Offline
                      jolran
                      Hi, tried using this plugin on Project of mine. Think there is an issue with Glue-ready-components having their axes not aligned to Global axes ?
                      Code is scrambled so can't tell what's up, bro πŸ˜‰ ..
                      See pic.
                      • hdpvH Offline
                        hdpv
                        Hi Jolran,
                        I'm fixing this error. It was because I used center's face instead of centerbounds's face
                        Suforyou
                        • jolranJ Offline
                          jolran
                          Well you could probably use something like
                          centerpoint = face.bounds.center.project_to_plane(face.plane), I gather.
                          However I don't think the alignment problem is comming from this ?
                          (the Component in pic is flipped backwards/upwards, part from not sticking to the face)
                          Are you using the face.normals to align or axes of Components?
                          Face normals would be more predictable, possibly. If getting the right nested transformations from the Group/Component, that is.
                          Anyway, thanks! Be willing to testdrive next version for some feedback.
                          • hdpvH Offline
                            hdpv
                            maybe,this problem is your Group/component have scale ,reset scale is no problem
                            I trying fix this problem.
                            Suforyou
                            • JBJDesignsJ Offline
                              JBJDesigns
                              Hi!
                              I've watched the video several times and have similar objects set-up to mimic what is being demonstrated. I'm not getting the same results; and it's probably because I'm missing something. For instance: I selected "Align Edges" tool; then I selected the edge of the largest object (as demonstrated); then holding down the "CTRL" key, I select the first small box; immediately the first box stretches out in a wedge shape and aligns itself with the larger box; only one object is effected -- if I click on the other small box, nothing happens. It looks pretty simple after viewing the video -- guess I could use some additional help. I've attached a picture to illustrate my point.
                              By the way, your other tools are outstanding especially the S4U to Components (already made a faceted table base and posted it on 3D Warehouse). So thanks for sharing! Jo πŸ˜„
                              ...you send them to school, you give them books, and they eat the pages...
                              • F Offline
                                function
                                i think this is great, it could increase workflow quite a bit
                                some issues: it seems to flip things upside down when I don't intend on it sometimes -
                                also I think the selection process should be opposite of what it is. right now you select target first and then the object you want aligned, but it makes a lot more sense to select the object you are working on and want to move to be selected first.
                                oh ya when you click the link to download in the sketchucation store plugin, SKP crashes 😲
                                • Rich O BrienR Online
                                  Fixed
                                  • F Offline
                                    function
                                    πŸ‘
                                    • F Offline
                                      function
                                      you don't hold control, you just press it
                                      • hdpvH Offline
                                        hdpv
                                        hi JBJDesigns!
                                        You can see status bar for instruction,
                                        -select target edge(face)
                                        -then press Ctrl if you want multiselect
                                        -select aligned edge(face)
                                        -press again Ctrl for finish select.
                                        press Tab for change "align" or "align and move"
                                        Suforyou
                                        • hdpvH Offline
                                          hdpv
                                          press Ctrl,not hold
                                          1-select target edge(face)
                                          2-then press Ctrl if you want multiselect
                                          3-select aligned edge(face)
                                          4-press again Ctrl for finish select.
                                          Suforyou
                                          • unclebimU Offline
                                            unclebim
                                            Wonderful plugin! Thanks! I use the Q JS Align plugin all the time but it works only along the three axes and I believe your plugin will go on top of the most used list now.
                                            • 1 / 3
