    [Plugin] s4u_Align
    45 Posts 16 Posters 33.4k Views 16 Watching
    • hdpvH
      hdpv
      Hi rv1974
      I've thought about it, I will try,
      I don't "Pre-Selecting object" because to easily select multiple objects(press enter or spacebar for finish selecting)
      Suforyou
      http://www.sketchupforyou.com
      • DETXD
        DETX
        Great many thanks.
        This plug help me very easy align object.
        Hope more features.
        • jolranJ
          jolran
          Hi, tried using this plugin on Project of mine. Think there is an issue with Glue-ready-components having their axes not aligned to Global axes ?
          Code is scrambled so can't tell what's up, bro πŸ˜‰ ..
          See pic.
          • hdpvH
            hdpv
            Hi Jolran,
            I'm fixing this error. It was because I used center's face instead of centerbounds's face
            Suforyou
            • jolranJ
              jolran
              Well you could probably use something like
              centerpoint = face.bounds.center.project_to_plane(face.plane), I gather.
              However I don't think the alignment problem is comming from this ?
              (the Component in pic is flipped backwards/upwards, part from not sticking to the face)
              Are you using the face.normals to align or axes of Components?
              Face normals would be more predictable, possibly. If getting the right nested transformations from the Group/Component, that is.
              Anyway, thanks! Be willing to testdrive next version for some feedback.
              • hdpvH
                hdpv
                maybe,this problem is your Group/component have scale ,reset scale is no problem
                I trying fix this problem.
                Suforyou
                • JBJDesignsJ
                  JBJDesigns
                  Hi!
                  I've watched the video several times and have similar objects set-up to mimic what is being demonstrated. I'm not getting the same results; and it's probably because I'm missing something. For instance: I selected "Align Edges" tool; then I selected the edge of the largest object (as demonstrated); then holding down the "CTRL" key, I select the first small box; immediately the first box stretches out in a wedge shape and aligns itself with the larger box; only one object is effected -- if I click on the other small box, nothing happens. It looks pretty simple after viewing the video -- guess I could use some additional help. I've attached a picture to illustrate my point.
                  By the way, your other tools are outstanding especially the S4U to Components (already made a faceted table base and posted it on 3D Warehouse). So thanks for sharing! Jo πŸ˜„
                  ...you send them to school, you give them books, and they eat the pages...
                  • F
                    function
                    i think this is great, it could increase workflow quite a bit
                    some issues: it seems to flip things upside down when I don't intend on it sometimes -
                    also I think the selection process should be opposite of what it is. right now you select target first and then the object you want aligned, but it makes a lot more sense to select the object you are working on and want to move to be selected first.
                    oh ya when you click the link to download in the sketchucation store plugin, SKP crashes 😲
                      Fixed
                      • F
                        function
                        πŸ‘
                        • F
                          function
                          you don't hold control, you just press it
                          • hdpvH
                            hdpv
                            hi JBJDesigns!
                            You can see status bar for instruction,
                            -select target edge(face)
                            -then press Ctrl if you want multiselect
                            -select aligned edge(face)
                            -press again Ctrl for finish select.
                            press Tab for change "align" or "align and move"
                            Suforyou
                            • hdpvH
                              hdpv
                              press Ctrl,not hold
                              1-select target edge(face)
                              2-then press Ctrl if you want multiselect
                              3-select aligned edge(face)
                              4-press again Ctrl for finish select.
                              Suforyou
                              • unclebimU
                                unclebim
                                Wonderful plugin! Thanks! I use the Q JS Align plugin all the time but it works only along the three axes and I believe your plugin will go on top of the most used list now.
                                • hdpvH
                                  hdpv
                                  Update s4u_AlignTool_v1.1.0 (25 April 2014)
                                  -Press UP, DOWN or Right Mouse for Mirror after align face
                                  Suforyou
                                  • hdpvH
                                    hdpv
                                    s4u-AlignTool 2.0.0 (10 June 2014)
                                    • align OUT group,multi-align with press hold Ctrl key.
                                      http://sketchucation.com/pluginstore?pln=s4u_aligntool_v1.0.4
                                    Suforyou
                                    • OxerO
                                      Oxer
                                      Thanks for the plugin, I created the Spanish Language File. I changed in the translation:
                                      Ctrl --> Ctrl(Pc)/Alt(Mac)
                                      The Ctrl key doesn't work on Mac.
                                      Spanish Language
                                      • hdpvH
                                        hdpv
                                        Thanks Oxer!
                                        I haven't checked for Mac yet.
                                        I will update later.
                                        Suforyou
                                        • kenK
                                          ken
                                          Installed the last version from the store, receive this error message now.
                                          Error Loading File C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb
                                          Error: #<NameError: uninitialized constant S4U::S4u_AlignTool::S4u_aligntoolStrings>
                                          C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb:11:in <module:S4u_AlignTool>' C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb:6:in module:S4U'
                                          C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb:3:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:14:in register_extension'
                                          C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:14:in <module:S4u_AlignTool>' C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:4:in module:S4U'
                                          C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:3:in `<top (required)>'
                                          Note: Re-installed from store. Not sure what happen, but all my toolbar were displaced.
                                          I see that no one else seems to be having this problem.
                                          Thanks for you replies.
                                          Ken
                                          • hdpvH
                                            hdpv
                                            Hi Ken!
                                            Delete files:
                                            and folder
                                            Don't rename file and folder plugin.
                                            Suforyou
                                            • 1 / 3
