    Vray Reflections
    renderpluginsextensions
    7 Posts 4 Posters 791 Views 4 Watching
    • H Offline
      hbk_dilip
      Test OutputHello Masters,
      I am new to Vray and Sketchup. I dont know how to make my glass render nicely. I am on SU 8 and latest VFS (Beta version) In my scene I have a dome light with HDRI for reflections but glass wont reflect 😞 vray render settings are default and dome light setting are default.
      Please see attach for the test output and glass setting(50% transparent with fresnel reflections)
      Can someone please help with some tips and techniques ? I am sure i am doing something very basic wrong..... : (
      Thanking you in advance for your help and your time.
      Glass setting
      • O Offline
        OSN58
        http://www.chaosgroup.com/forums/vbulletin/showthread.php?73190-Dome-light-Affect-Reflections-feature-not-working
        • V Offline
          valerostudio
          Put the same HDRI in your BG slot and see if you get the same results.
          Also, seems like you want to adjust the intensity of that HDRI, it looks really dark, like a tornado is coming.
          • H Offline
            hbk_dilip
            Thank you sir,
            I will try what you suggested and post my result.
            Thanks once again, I hope it works..
            • andybotA Offline
              andybot
              did you check on the "visibility" option in your domelight texture?
              • H Offline
                hbk_dilip
                Seems like it was a bad HDRI image for this render, I got better reflections when i changed the HDRI image. Changing dome light multiplier helped. Thank you valerostudio and andybot for looking into it and for your suggestions. I will post a test render soon.
                Thank you...
                • V Offline
                  valerostudio
                  Try here http://www.hdri-hub.com/ great HDRI files and they sponsor SketchUcation.
