    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Plugin] s4u_toComponents
    89 Posts 26 Posters 98.4k Views 26 Watching
      boilingsnow
      Great plugin!
      thank you.
      • hdpvH Offline
        hdpv
        @boilingsnow said:
        Great plugin!
        thank you.
        Hope you like new feature too!
        Suforyou
        http://www.sketchupforyou.com
        • G Offline
          gfgfgfgfgf10
          hi dear
          15 dollars !!!
          what do you think about us ???
          do you think we are rockefeller in new york city !!!
          πŸ˜’ πŸ˜’ πŸ˜’
          • hdpvH Offline
            hdpv
            if you can't ,you use this free plugin
            http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
            it's like my plugin. πŸ˜‰
            Suforyou
              laudhi
              @gfgfgfgfgf10 said:
              hi dear
              15 dollars !!!
              πŸ˜’ πŸ˜’ πŸ˜’
              you do not have to be rockefeller to buy this plugin... 😎
              better spend $ 15 rather than i have to make this plugin... πŸ˜‰
              • Y Offline
                yohdubato
                Hello,
                A member of thea render's forum told me to post my work to explain how great is your plugin !!! πŸ˜„
                I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
                it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, eiffel with su4u.jpgyour plug is still a must πŸ˜„
                πŸ‘ πŸ‘ πŸ‘
                • hdpvH Offline
                  hdpv
                  Yohdubato! nice model! πŸ˜„
                  You can reset scale component by 2 plugins
                  s4u_Scaletool ,free
                  http://sketchucation.com/pluginstore?pln=s4u_scaletool
                  or
                  s4u Transformer,20$ (selectable origin components)
                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
                  Cheers!
                  Suforyou
                  • Y Offline
                    yohdubato
                    thanks for your links ; those plugins are great too!!!
                    i will try them πŸ˜„
                    πŸ‘ ++
                      cruelcomedy
                      I want this plugin, how do I get the full version and how do I pay for this?
                      http://www.richarddoble.com/
                      • hdpvH Offline
                        hdpv
                        Hi Cruelcomedy!
                        Price: 15$
                        Send to my paypal (suforyou.vn@gmail.com) for get it.
                        Suforyou
                          cruelcomedy
                          sent the money for the slice and this plugin! I'm excited! thank you for your amazing plugins!
                          • hdpvH Offline
                            hdpv
                            Thanks! Check your mail!
                            Suforyou
                              Cool model of the French monument! πŸ‘
                              What a patience! πŸ˜„
                              Try this site! β˜€
                              • G Offline
                                g.moggel
                                you know what would be awesome?
                                to be able to fit a component onto a face depending on the textures orientation on that face.
                                i try to optimize some tree models and they have the leaf texture aplied. the leaves are a flat plane though. i would like to fit a component with more complex geometry on it that would replace the leaves with actual geometry. problem is if i use your plugin the orientation is totaly different on each plane. would it be possible to use the texture coordinates to arrange a component on it? the texture would need to be somewhat the same size.
                                see all the images attached. i marked where the leaf stem would need to go.
                                this would be so useful to me and i'm sure some other archviz guys.
                                cheers and thanks for your hard work. i already have your slice plugin and its amazing!
                                cheers,
                                mo
                                • hdpvH Offline
                                  hdpv
                                  Hi Mo!
                                  I understand you, I will try to do.
                                  Suforyou
                                  • hdpvH Offline
                                    hdpv
                                    I have been updated:
                                    • Make faces to Components follow origin face's texture
                                    • Replace Components by selected component.
                                      http://extensions.sketchup.com/en/content/s4u-components
                                    Suforyou
                                      Allways so cool! 😎
                                      Apply twice on a simple box! πŸ˜„
                                      • N Offline
                                        numerobis
                                        I have installed the trial version of this nice plugin and i have a weird problem - i'm not sure if i'm doing something wrong or if it is a bug...?!?
                                        I can't get it to replace all faces with instances (using "Faces to Components"), only the panels that are selected in the screenshot are the same components, all the other panels become unique components... πŸ˜•
                                        http://i57.tinypic.com/34e2u6x.jpg
                                        And it's always the same shape of panels.
                                        Is this a bug or a feature?
                                        • N Offline
                                          numerobis
                                          So is ist not possible to get a a result with instanced components over the whole object?
                                          Btw. how long does the trial period goes? I couldn't find any info about it.
                                          • hdpvH Offline
                                            hdpv
                                            Trial Period: 15 days
                                            Suforyou
                                            • 4 / 5
