    [Plugin] s4u_toComponents
    89 Posts 26 Posters 108.6k Views 26 Watching
      Made with Extrude Tools by TIG
      Weld Curves : Recurve by Digssey
      Selection Toys by Thomthom
      Make 2 Arcs Circles + 1 profile
      (option Quadrilaters)
      Trick is Select only Soft Edges then Kill them
      • DareDevilD
        DareDevil
        I just tried Faces to Components with SU pro's dynamic components and it works 😍
        Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
        The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
        • B
          boilingsnow
          Great plugin!
          thank you.
          • hdpvH
            hdpv
            @boilingsnow said:
            Great plugin!
            thank you.
            Hope you like new feature too!
            Suforyou
            http://www.sketchupforyou.com
            • G
              gfgfgfgfgf10
              hi dear
              15 dollars !!!
              what do you think about us ???
              do you think we are rockefeller in new york city !!!
              πŸ˜’ πŸ˜’ πŸ˜’
              • hdpvH
                hdpv
                if you can't ,you use this free plugin
                http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
                it's like my plugin. πŸ˜‰
                Suforyou
                • L
                  laudhi
                  @gfgfgfgfgf10 said:
                  hi dear
                  15 dollars !!!
                  πŸ˜’ πŸ˜’ πŸ˜’
                  you do not have to be rockefeller to buy this plugin... 😎
                  better spend $ 15 rather than i have to make this plugin... πŸ˜‰
                  • Y
                    yohdubato
                    Hello,
                    A member of thea render's forum told me to post my work to explain how great is your plugin !!! πŸ˜„
                    I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
                    it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, eiffel with su4u.jpgyour plug is still a must πŸ˜„
                    πŸ‘ πŸ‘ πŸ‘
                    • hdpvH
                      hdpv
                      Yohdubato! nice model! πŸ˜„
                      You can reset scale component by 2 plugins
                      s4u_Scaletool ,free
                      http://sketchucation.com/pluginstore?pln=s4u_scaletool
                      or
                      s4u Transformer,20$ (selectable origin components)
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
                      Cheers!
                      Suforyou
                      • Y
                        yohdubato
                        thanks for your links ; those plugins are great too!!!
                        i will try them πŸ˜„
                        πŸ‘ ++
                        • C
                          cruelcomedy
                          I want this plugin, how do I get the full version and how do I pay for this?
                          http://www.richarddoble.com/
                          • hdpvH
                            hdpv
                            Hi Cruelcomedy!
                            Price: 15$
                            Send to my paypal (suforyou.vn@gmail.com) for get it.
                            Suforyou
                            • C
                              cruelcomedy
                              sent the money for the slice and this plugin! I'm excited! thank you for your amazing plugins!
                              • hdpvH
                                hdpv
                                Thanks! Check your mail!
                                Suforyou
                                  Cool model of the French monument! πŸ‘
                                  What a patience! πŸ˜„
                                  Try this site! β˜€
                                  • G
                                    g.moggel
                                    you know what would be awesome?
                                    to be able to fit a component onto a face depending on the textures orientation on that face.
                                    i try to optimize some tree models and they have the leaf texture aplied. the leaves are a flat plane though. i would like to fit a component with more complex geometry on it that would replace the leaves with actual geometry. problem is if i use your plugin the orientation is totaly different on each plane. would it be possible to use the texture coordinates to arrange a component on it? the texture would need to be somewhat the same size.
                                    see all the images attached. i marked where the leaf stem would need to go.
                                    this would be so useful to me and i'm sure some other archviz guys.
                                    cheers and thanks for your hard work. i already have your slice plugin and its amazing!
                                    cheers,
                                    mo
                                    • hdpvH
                                      hdpv
                                      Hi Mo!
                                      I understand you, I will try to do.
                                      Suforyou
                                      • hdpvH
                                        hdpv
                                        I have been updated:
                                        • Make faces to Components follow origin face's texture
                                        • Replace Components by selected component.
                                          http://extensions.sketchup.com/en/content/s4u-components
                                        Suforyou
                                          Allways so cool! 😎
                                          Apply twice on a simple box! πŸ˜„
                                          • N
                                            numerobis
                                            I have installed the trial version of this nice plugin and i have a weird problem - i'm not sure if i'm doing something wrong or if it is a bug...?!?
                                            I can't get it to replace all faces with instances (using "Faces to Components"), only the panels that are selected in the screenshot are the same components, all the other panels become unique components... πŸ˜•
                                            http://i57.tinypic.com/34e2u6x.jpg
                                            And it's always the same shape of panels.
                                            Is this a bug or a feature?
                                            • 4 / 5
