    [Plugin] s4u_toComponents
    89 Posts 26 Posters 103.9k Views 26 Watching
    • DareDevilD Offline
      DareDevil
      I just tried Faces to Components with SU pro's dynamic components and it works 😍
      Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
      The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
        boilingsnow
        Great plugin!
        thank you.
        • hdpvH Offline
          hdpv
          @boilingsnow said:
          Great plugin!
          thank you.
          Hope you like new feature too!
          Suforyou
          http://www.sketchupforyou.com
            gfgfgfgfgf10
            hi dear
            15 dollars !!!
            what do you think about us ???
            do you think we are rockefeller in new york city !!!
            πŸ˜’ πŸ˜’ πŸ˜’
            • hdpvH Offline
              hdpv
              if you can't ,you use this free plugin
              http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
              it's like my plugin. πŸ˜‰
              Suforyou
                laudhi
                @gfgfgfgfgf10 said:
                hi dear
                15 dollars !!!
                πŸ˜’ πŸ˜’ πŸ˜’
                you do not have to be rockefeller to buy this plugin... 😎
                better spend $ 15 rather than i have to make this plugin... πŸ˜‰
                • Y Offline
                  yohdubato
                  Hello,
                  A member of thea render's forum told me to post my work to explain how great is your plugin !!! πŸ˜„
                  I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
                  it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, eiffel with su4u.jpgyour plug is still a must πŸ˜„
                  πŸ‘ πŸ‘ πŸ‘
                  • hdpvH Offline
                    hdpv
                    Yohdubato! nice model! πŸ˜„
                    You can reset scale component by 2 plugins
                    s4u_Scaletool ,free
                    http://sketchucation.com/pluginstore?pln=s4u_scaletool
                    or
                    s4u Transformer,20$ (selectable origin components)
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
                    Cheers!
                    Suforyou
                    • Y Offline
                      yohdubato
                      thanks for your links ; those plugins are great too!!!
                      i will try them πŸ˜„
                      πŸ‘ ++
                        cruelcomedy
                        I want this plugin, how do I get the full version and how do I pay for this?
                        http://www.richarddoble.com/
                        • hdpvH Offline
                          hdpv
                          Hi Cruelcomedy!
                          Price: 15$
                          Send to my paypal (suforyou.vn@gmail.com) for get it.
                          Suforyou
                            cruelcomedy
                            sent the money for the slice and this plugin! I'm excited! thank you for your amazing plugins!
                            • hdpvH Offline
                              hdpv
                              Thanks! Check your mail!
                              Suforyou
                                Cool model of the French monument! πŸ‘
                                What a patience! πŸ˜„
                                Try this site! β˜€
                                  g.moggel
                                  you know what would be awesome?
                                  to be able to fit a component onto a face depending on the textures orientation on that face.
                                  i try to optimize some tree models and they have the leaf texture aplied. the leaves are a flat plane though. i would like to fit a component with more complex geometry on it that would replace the leaves with actual geometry. problem is if i use your plugin the orientation is totaly different on each plane. would it be possible to use the texture coordinates to arrange a component on it? the texture would need to be somewhat the same size.
                                  see all the images attached. i marked where the leaf stem would need to go.
                                  this would be so useful to me and i'm sure some other archviz guys.
                                  cheers and thanks for your hard work. i already have your slice plugin and its amazing!
                                  cheers,
                                  mo
                                  • hdpvH Offline
                                    hdpv
                                    Hi Mo!
                                    I understand you, I will try to do.
                                    Suforyou
                                    • hdpvH Offline
                                      hdpv
                                      I have been updated:
                                      • Make faces to Components follow origin face's texture
                                      • Replace Components by selected component.
                                        http://extensions.sketchup.com/en/content/s4u-components
                                      Suforyou
                                        Allways so cool! 😎
                                        Apply twice on a simple box! πŸ˜„
                                        • N Offline
                                          numerobis
                                          I have installed the trial version of this nice plugin and i have a weird problem - i'm not sure if i'm doing something wrong or if it is a bug...?!?
                                          I can't get it to replace all faces with instances (using "Faces to Components"), only the panels that are selected in the screenshot are the same components, all the other panels become unique components... πŸ˜•
                                          http://i57.tinypic.com/34e2u6x.jpg
                                          And it's always the same shape of panels.
                                          Is this a bug or a feature?
                                          • N Offline
                                            numerobis
                                            So is ist not possible to get a a result with instanced components over the whole object?
                                            Btw. how long does the trial period goes? I couldn't find any info about it.
                                            • 4 / 5
