    [Plugin] s4u_toComponents
    89 Posts 26 Posters 108.6k Views 26 Watching
    • hdpvH
      hdpv
      It's free for super tester Pillou! πŸ˜„
      Suforyou
      http://www.sketchupforyou.com
        Magic of the auto similarity no uniform! πŸ˜„
        http://s6.postimg.org/ujv4ivopd/simili1.jpg
        • hdpvH
          hdpv
          Additional,It work correct for all sublevel of Component,keep hierarchy.
          Suforyou
            Very cool! β˜€
            And when you have triangular face use
            Quadrilateralizater by TIG
            http://s6.postimg.org/u9wukide9/quads.jpg
            PS For the inverse
            by Renderiza Face Split triangulate all faces! β˜€
            • hdpvH
              hdpv
              Good combination! πŸ˜„
              Suforyou
                Made with Extrude Tools by TIG
                Weld Curves : Recurve by Digssey
                Selection Toys by Thomthom
                Make 2 Arcs Circles + 1 profile
                (option Quadrilaters)
                Trick is Select only Soft Edges then Kill them
                • DareDevilD
                  DareDevil
                  I just tried Faces to Components with SU pro's dynamic components and it works 😍
                  Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
                  The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
                  • B
                    boilingsnow
                    Great plugin!
                    thank you.
                    • hdpvH
                      hdpv
                      @boilingsnow said:
                      Great plugin!
                      thank you.
                      Hope you like new feature too!
                      Suforyou
                      • G
                        gfgfgfgfgf10
                        hi dear
                        15 dollars !!!
                        what do you think about us ???
                        do you think we are rockefeller in new york city !!!
                        πŸ˜’ πŸ˜’ πŸ˜’
                        • hdpvH
                          hdpv
                          if you can't ,you use this free plugin
                          http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
                          it's like my plugin. πŸ˜‰
                          Suforyou
                          • L
                            laudhi
                            @gfgfgfgfgf10 said:
                            hi dear
                            15 dollars !!!
                            πŸ˜’ πŸ˜’ πŸ˜’
                            you do not have to be rockefeller to buy this plugin... 😎
                            better spend $ 15 rather than i have to make this plugin... πŸ˜‰
                            • Y
                              yohdubato
                              Hello,
                              A member of thea render's forum told me to post my work to explain how great is your plugin !!! πŸ˜„
                              I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
                              it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, eiffel with su4u.jpgyour plug is still a must πŸ˜„
                              πŸ‘ πŸ‘ πŸ‘
                              • hdpvH
                                hdpv
                                Yohdubato! nice model! πŸ˜„
                                You can reset scale component by 2 plugins
                                s4u_Scaletool ,free
                                http://sketchucation.com/pluginstore?pln=s4u_scaletool
                                or
                                s4u Transformer,20$ (selectable origin components)
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
                                Cheers!
                                Suforyou
                                • Y
                                  yohdubato
                                  thanks for your links ; those plugins are great too!!!
                                  i will try them πŸ˜„
                                  πŸ‘ ++
                                  • C
                                    cruelcomedy
                                    I want this plugin, how do I get the full version and how do I pay for this?
                                    http://www.richarddoble.com/
                                    • hdpvH
                                      hdpv
                                      Hi Cruelcomedy!
                                      Price: 15$
                                      Send to my paypal (suforyou.vn@gmail.com) for get it.
                                      Suforyou
                                      • C
                                        cruelcomedy
                                        sent the money for the slice and this plugin! I'm excited! thank you for your amazing plugins!
                                        • hdpvH
                                          hdpv
                                          Thanks! Check your mail!
                                          Suforyou
                                            Cool model of the French monument! πŸ‘
                                            What a patience! πŸ˜„
                                            Try this site! β˜€
                                            • 4 / 5
