    [Plugin] s4u_toComponents
    89 Posts 26 Posters 104.2k Views 26 Watching
    • hdpvH Offline
      hdpv
      Yohdubato! nice model! πŸ˜„
      You can reset scale component by 2 plugins
      s4u_Scaletool ,free
      http://sketchucation.com/pluginstore?pln=s4u_scaletool
      or
      s4u Transformer,20$ (selectable origin components)
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
      Cheers!
      Suforyou
      http://www.sketchupforyou.com
      • Y Offline
        yohdubato
        thanks for your links ; those plugins are great too!!!
        i will try them πŸ˜„
        πŸ‘ ++
          cruelcomedy
          I want this plugin, how do I get the full version and how do I pay for this?
          http://www.richarddoble.com/
          • hdpvH Offline
            hdpv
            Hi Cruelcomedy!
            Price: 15$
            Send to my paypal (suforyou.vn@gmail.com) for get it.
            Suforyou
              cruelcomedy
              sent the money for the slice and this plugin! I'm excited! thank you for your amazing plugins!
              • hdpvH Offline
                hdpv
                Thanks! Check your mail!
                Suforyou
                  Cool model of the French monument! πŸ‘
                  What a patience! πŸ˜„
                  Try this site! β˜€
                    g.moggel
                    you know what would be awesome?
                    to be able to fit a component onto a face depending on the textures orientation on that face.
                    i try to optimize some tree models and they have the leaf texture aplied. the leaves are a flat plane though. i would like to fit a component with more complex geometry on it that would replace the leaves with actual geometry. problem is if i use your plugin the orientation is totaly different on each plane. would it be possible to use the texture coordinates to arrange a component on it? the texture would need to be somewhat the same size.
                    see all the images attached. i marked where the leaf stem would need to go.
                    this would be so useful to me and i'm sure some other archviz guys.
                    cheers and thanks for your hard work. i already have your slice plugin and its amazing!
                    cheers,
                    mo
                    • hdpvH Offline
                      hdpv
                      Hi Mo!
                      I understand you, I will try to do.
                      Suforyou
                      • hdpvH Offline
                        hdpv
                        I have been updated:
                        • Make faces to Components follow origin face's texture
                        • Replace Components by selected component.
                          http://extensions.sketchup.com/en/content/s4u-components
                        Suforyou
                          Allways so cool! 😎
                          Apply twice on a simple box! πŸ˜„
                          • N Offline
                            numerobis
                            I have installed the trial version of this nice plugin and i have a weird problem - i'm not sure if i'm doing something wrong or if it is a bug...?!?
                            I can't get it to replace all faces with instances (using "Faces to Components"), only the panels that are selected in the screenshot are the same components, all the other panels become unique components... πŸ˜•
                            http://i57.tinypic.com/34e2u6x.jpg
                            And it's always the same shape of panels.
                            Is this a bug or a feature?
                            • N Offline
                              numerobis
                              So is ist not possible to get a a result with instanced components over the whole object?
                              Btw. how long does the trial period goes? I couldn't find any info about it.
                              • hdpvH Offline
                                hdpv
                                Trial Period: 15 days
                                Suforyou
                                • N Offline
                                  numerobis
                                  And what about the other question? Not possible? Or do i need to use a different tool instead of "Faces to Components"?
                                  • hdpvH Offline
                                    hdpv
                                    Not possible for all object.Unless you divide faces to triangle
                                    You need use a diferrent tool.
                                    Suforyou
                                    • hdpvH Offline
                                      hdpv
                                      Hi Numerobis!
                                      The same components if face is rectangle or parallelogram.
                                      about trapezium ,the same components if face is uniform.
                                      about triangle ,all the same components.
                                      Version 5.1.0 is some bug,I fixed it in curent version v5.2.1 .
                                      Suforyou
                                      • N Offline
                                        numerobis
                                        Ok, thanks for clarifying this.
                                        So what different tool would this be?
                                          French UI πŸ˜‰
                                          Very cool for fractal volumes in 3 seconds! 😎
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9562508_orig.gif
                                          fr.zip
                                          • hdpvH Offline
                                            hdpv
                                            Merci Pilou! πŸ˜„
                                            Suforyou
                                            • 4 / 5
