    [Plugin] s4u_toComponents
    89 Posts 26 Posters 106.0k Views 26 Watching
    • hdpvH Offline
      hdpv
      Additional,It work correct for all sublevel of Component,keep hierarchy.
      Suforyou
      http://www.sketchupforyou.com
        Very cool! β˜€
        And when you have triangular face use
        Quadrilateralizater by TIG
        http://s6.postimg.org/u9wukide9/quads.jpg
        PS For the inverse
        by Renderiza Face Split triangulate all faces! β˜€
        • hdpvH Offline
          hdpv
          Good combination! πŸ˜„
          Suforyou
            Made with Extrude Tools by TIG
            Weld Curves : Recurve by Digssey
            Selection Toys by Thomthom
            Make 2 Arcs Circles + 1 profile
            (option Quadrilaters)
            Trick is Select only Soft Edges then Kill them
            • DareDevilD Offline
              DareDevil
              I just tried Faces to Components with SU pro's dynamic components and it works 😍
              Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
              The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
                boilingsnow
                Great plugin!
                thank you.
                • hdpvH Offline
                  hdpv
                  @boilingsnow said:
                  Great plugin!
                  thank you.
                  Hope you like new feature too!
                  Suforyou
                    gfgfgfgfgf10
                    hi dear
                    15 dollars !!!
                    what do you think about us ???
                    do you think we are rockefeller in new york city !!!
                    πŸ˜’ πŸ˜’ πŸ˜’
                    • hdpvH Offline
                      hdpv
                      if you can't ,you use this free plugin
                      http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
                      it's like my plugin. πŸ˜‰
                      Suforyou
                        laudhi
                        @gfgfgfgfgf10 said:
                        hi dear
                        15 dollars !!!
                        πŸ˜’ πŸ˜’ πŸ˜’
                        you do not have to be rockefeller to buy this plugin... 😎
                        better spend $ 15 rather than i have to make this plugin... πŸ˜‰
                        • Y Offline
                          yohdubato
                          Hello,
                          A member of thea render's forum told me to post my work to explain how great is your plugin !!! πŸ˜„
                          I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
                          it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, eiffel with su4u.jpgyour plug is still a must πŸ˜„
                          πŸ‘ πŸ‘ πŸ‘
                          • hdpvH Offline
                            hdpv
                            Yohdubato! nice model! πŸ˜„
                            You can reset scale component by 2 plugins
                            s4u_Scaletool ,free
                            http://sketchucation.com/pluginstore?pln=s4u_scaletool
                            or
                            s4u Transformer,20$ (selectable origin components)
                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
                            Cheers!
                            Suforyou
                            • Y Offline
                              yohdubato
                              thanks for your links ; those plugins are great too!!!
                              i will try them πŸ˜„
                              πŸ‘ ++
                                cruelcomedy
                                I want this plugin, how do I get the full version and how do I pay for this?
                                http://www.richarddoble.com/
                                • hdpvH Offline
                                  hdpv
                                  Hi Cruelcomedy!
                                  Price: 15$
                                  Send to my paypal (suforyou.vn@gmail.com) for get it.
                                  Suforyou
                                    cruelcomedy
                                    sent the money for the slice and this plugin! I'm excited! thank you for your amazing plugins!
                                    • hdpvH Offline
                                      hdpv
                                      Thanks! Check your mail!
                                      Suforyou
                                        Cool model of the French monument! πŸ‘
                                        What a patience! πŸ˜„
                                        Try this site! β˜€
                                          g.moggel
                                          you know what would be awesome?
                                          to be able to fit a component onto a face depending on the textures orientation on that face.
                                          i try to optimize some tree models and they have the leaf texture aplied. the leaves are a flat plane though. i would like to fit a component with more complex geometry on it that would replace the leaves with actual geometry. problem is if i use your plugin the orientation is totaly different on each plane. would it be possible to use the texture coordinates to arrange a component on it? the texture would need to be somewhat the same size.
                                          see all the images attached. i marked where the leaf stem would need to go.
                                          this would be so useful to me and i'm sure some other archviz guys.
                                          cheers and thanks for your hard work. i already have your slice plugin and its amazing!
                                          cheers,
                                          mo
                                          • hdpvH Offline
                                            hdpv
                                            Hi Mo!
                                            I understand you, I will try to do.
                                            Suforyou
                                            • 4 / 5
