    Lock to Parallel or Perpendicular lines
    3 Posts 3 Posters 4.6k Views 3 Watching
    • P
      payden
      Just as you can lock onto the x,y, and z axis with the arrow keys when measuring or drawing a line. There are times where you can follow the pink-line-tracking to continue a line that is parallel or perpendicular...not at all times does it lock onto pink, so as a solution:Is there a plugin or undiscovered way to lock on to drawing a line that is perpendicular or parallel (pink line tracking)...In other words, can you lock to the pink tracking or hot key like you can with axis locks?
      • massimoM
        massimo Moderator
        Just press "shift" key once you get that pink-line to lock the direction.
        • cottyC
          cotty
          Yes, some more hints in the help about inference locking...
          my SketchUp gallery
