    This method of apply color working?
    14 Posts 3 Posters 904 Views 3 Watching
    • renderizaR
      renderiza
      I was testing the following;
      face.material = "#ff0000"
      Why is this not working?
      Here is the link on SketchUP API... http://www.sketchup.com/intl/en/developer/docs/ourdoc/color.php
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • thomthomT
        Works for me...
        Sketchup.active_model.selection[0].material = "#ff0000"
        What happens for you?
        • TIGT
          Works fine for me too...
          Perhaps your reference ' face' is invalid ?
          • renderizaR
            renderiza
            Hi, here is an example of what I a did...
            model = Sketchup.active_model
            ents = model.active_entities
            faces = ents.grep(Sketchup;;Face)
            materials = model.materials
            m = materials.add "shadow"
            faces.each do |e|
                e.material = [255, 0, 0] # <--This Works
                e.material = "#ff0000" # <--This Do Not
            You can see full code on here...http://sketchucation.com/forums/viewtopic.php?f=323&t=52871
            Since I had the input result come in hex mode thru web-dialog what I did to make it work on Ruby was to first change it into RGB in Javascript. πŸ˜•
            Cheers!
            • thomthomT
              What happens when it "doesn't work"? Error messages?
              Your snippet works for me...
              • renderizaR
                renderiza
                Interesting...
                Doesn't work on SU 8 but works on SU 2013.
                Is that suppose to happen?
                • thomthomT
                  Probably a new feature then.
                  Which explain why I couldn't remember seeing that way of assigning material. (Which I'd written about in my blog: http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/#hexadecimal-notation )
                  • thomthomT
                    Seems to be a new feature of the Sketchup::Color class.
                    ` Sketchup::Color.new '#ff0000'
                    Color(255, 0, 0, 255)
                    Sketchup::Color.new '#f00'
                    Color(255, 0, 0, 255)`
                    Works in SU2013 - but not SU8. And Not documented in the docs when it was implemented.
                    • renderizaR
                      renderiza
                      I see that explains everything. πŸ‘
                      It is very good that SketchUp API is being updated...hope to see more changes in the future.
                      cheers!
                      • thomthomT
                        Yea - I've noticed some changes here and there recently.
                        • TIGT
                          It has been shown in the API for years, but I think it was broken until v2013...
                          • thomthomT
                            0x0000FF has always worked. Was it not that that was displayed?
                            • thomthomT
                              ah... I just checked the Way Back Machine... it was there before SU2013.
                              http://web.archive.org/web/20130509194228/http://www.sketchup.com/intl/en/developer/docs/ourdoc/color
                              • TIGT
                                That was and is displayed.
                                But it think the string equivalent was always shown but just didn't work until now πŸ˜•
