    This method of apply color working?
    14 Posts 3 Posters 429 Views 3 Watching
    • renderizaR Offline
      renderiza
      I was testing the following;
      face.material = "#ff0000"
      Why is this not working?
      Here is the link on SketchUP API... http://www.sketchup.com/intl/en/developer/docs/ourdoc/color.php
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Works for me...
        Sketchup.active_model.selection[0].material = "#ff0000"
        What happens for you?
          Works fine for me too...
          Perhaps your reference ' face' is invalid ?
            renderiza
            Hi, here is an example of what I a did...
            model = Sketchup.active_model
            ents = model.active_entities
            faces = ents.grep(Sketchup;;Face)
            materials = model.materials
            m = materials.add "shadow"
            faces.each do |e|
                e.material = [255, 0, 0] # <--This Works
                e.material = "#ff0000" # <--This Do Not
            You can see full code on here...http://sketchucation.com/forums/viewtopic.php?f=323&t=52871
            Since I had the input result come in hex mode thru web-dialog what I did to make it work on Ruby was to first change it into RGB in Javascript. πŸ˜•
            Cheers!
              What happens when it "doesn't work"? Error messages?
              Your snippet works for me...
                renderiza
                Interesting...
                Doesn't work on SU 8 but works on SU 2013.
                Is that suppose to happen?
                  Probably a new feature then.
                  Which explain why I couldn't remember seeing that way of assigning material. (Which I'd written about in my blog: http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/#hexadecimal-notation )
                    Seems to be a new feature of the Sketchup::Color class.
                    ` Sketchup::Color.new '#ff0000'
                    Color(255, 0, 0, 255)
                    Sketchup::Color.new '#f00'
                    Color(255, 0, 0, 255)`
                    Works in SU2013 - but not SU8. And Not documented in the docs when it was implemented.
                      renderiza
                      I see that explains everything. πŸ‘
                      It is very good that SketchUp API is being updated...hope to see more changes in the future.
                      cheers!
                        Yea - I've noticed some changes here and there recently.
                          It has been shown in the API for years, but I think it was broken until v2013...
                            0x0000FF has always worked. Was it not that that was displayed?
                              ah... I just checked the Way Back Machine... it was there before SU2013.
                              SketchUp Ruby API
                              (web.archive.org)
                                That was and is displayed.
                                But it think the string equivalent was always shown but just didn't work until now πŸ˜•
