    Selecting only lines
    4 Posts 4 Posters 699 Views 4 Watching
    • S
      Snowfield
      I find it irritating when I'm trying to select a line (edge) and a surface behind the line gets selected instead. Is there a way of telling sketchup when I'm only wanting to select lines?
      Often a line is running along the edge of a long cylinder (which is also made up of lines). Is there an easy way to get sketchup to select the line I have drawn rather than the lines of something else?
      • J
        JuanV.Soler
        I think you´ll like it 😉
        http://sketchucation.com/forums/viewtopic.php?t=45995
        • panixiaP
          panixia
          http://sketchucation.com/forums/viewtopic.php?f=323&t=14975&hilit=selection+toys
          • jgbJ
            jgb
            I've used Selection Toys for a while (new V2.2 is out, which I have not yet installed)
            I keep "Entity Info" dialog open at all times in the upper right of screen.
            ABOVE it is a simple Selection Toys toolbar, where I have just a few icons I use the most, that is: Select Lines, Faces, Groups, Components, Hidden, Soft, Smooth, as well as deselect same list.
            jgb
