    [Plugin] TIG-ElevTag v1.0 20130603
    12 Posts 8 Posters 12.9k Views 8 Watching
    • TIGT
      (c) TIG 2013
      All rights reserved.
      TIG-ElevTag.rb
      Loads Extension TIG-ElevTag.rb from ../Plugins/TIG-ElevTag subfolder
      Requires the component ElevTag.skp [v7] in the same subfolder.
      Usage:
      From right-click context-submenu only: 'ElevTag...'
      'Add...'
      This lets you place an 'ElevTag' instance in your model.
      Then you can Move/Rotate it as desired.
      Its initial state is with all 4 pointers shown [ABCD] and the 'Refs' = 1 and 2.
      When you select another tool [say Select <spacebar>] to complete the
      placement/adjustment then a dialog opens.
      This is the same dialog as if later you had selected an 'ElevTag' and used the
      context-submenu and chosen...
      'Edit & Scene-Tab...'
      Note: this only appears if an 'ElevTag' instance or equivalent group is selected.
      This opens a dialog that will let you set its:
      =Type : the ABCD arrows to display - all the permutations of the 1/2/3/4 arrows,
      the initial default = 'ABCD'.
      =Ref 1: the text in the top part of the circle - default = '1'
      =Ref 2: the text in the bottom part of the circle - default = '2'
      keep to 1 to 5 characters, to keep within the circle...
      =Show 'ABCD' ? : to control visibility of the Arrow text 'A' etc, Yes|No,
      [initial default = Yes]; useful with single arrows where it'd be superfluous,
      so s Single-Arrow's Scene-Tab Name will not include the ElevTag's 'Type' letter
      if 'Show?' is set to 'No'. Multiple-Arrow Scene-Tabs Names always include the
      'type' letter even when 'Show?' is 'No' because otherwise they cannot be
      named separately.
      =Target Distance: [in current-units] controls the initial zoom size
      [you can always zoom in/out later and update the Scene-Tab],
      a smaller distance == a closer zoom.
      =Click OK and the initial ElevTag Instance is converted into a Group
      [unless it is already one and you are now editing it later on], this Group is
      named after the Options e.g. 'ElevTag-AC-1-2.3'
      and the chosen Options are then effected.
      =Click Cancel NOT to change Options.
      A second dialog then asks if you want to make Make the Scene-Tabs for each of
      the Arrows:
      Yes: to Make it.
      No: to Skip it.
      If 'Show?'=='No' then Single-Arrow ElevTag Scene-Tab's Name will not have the
      'Type' letter, e.g.
      Elev-1-2.1
      If 'Show?'=='Yes' then Single-Arrow ElevTag Scene-Tab's Name will have the
      'Type' letter, e.g.
      Elev-A-1-2.1
      All Multiple-Arrow ElevTag Scene-Tabs' Names will always be prefixed with their
      'Type' letter, irrespective of the 'Show?' setting:
      Elev-A-1-2.3
      Elev-B-1-2.3
      etc...
      If a Scene-Tab already exists with a specified 'Name', then the dialog is
      different - it warns you and offers:
      Yes: to Change it.
      No: to Skip it.
      Cancel: to Abort the Operation and Change the ElevTag Options in a reopened
      dialog.
      Note how the dialog's last used Values for the ABCD, Show?, Target etc are
      reused during that session.
      Never rename an 'ElevTag-...' Group as it will no longer be recognized for
      Editing etc...
      Never edit an 'ElevTag-...' Group and delete entities within it, as I then won't
      work properly...
      Never change the contents of the 'ElevTag' SKP in the tool's subfolder.
      = v8 only.
      Donations: PayPal.com info @ revitrev.org
      Version:
      1.0 20130530 First release.
      Available for download at the 'SCF PluginStore'
      http://sketchucation.com/resources/pluginstore?pln=ElevTag
      Or for AutoInstall from the 'SketcUcation Plugin Store' dialog from within SketchUp itself...
      http://sketchucation.com/resources/plugin-store-download
      • B
        Ben Ritter
        TIG, thank you for another one. You are very generous.
        • KrisidiousK
          Krisidious
          πŸ‘ Likes this... πŸ‘
          By: Kristoff Rand
          • S
            sepo
            πŸ‘
            • T
              tald311
              This looks promising and needed. Thank you!!
              • J
                JuanV.Soler
                very cool and handy TIG
                many thanks
                • R
                  RodolfoST
                  Hi! This plugin is exactly what I was looking for. Thank you!
                  Is it possible to place the solid section on the walls? I also noticed that the view is at the tag level. I think it would have been better if the view was positioned 1.5m above the tag.
                  • TIGT
                    To try this yourself... open the file ../Plugins/TIG-ElevTag/TIG-ElevTag.rb
                    Use a plain-text editor like Notepad++ or TextWrangler.
                    Find line #266 [it reads " up=tr.zaxis"] and insert a new line after it, with this text:
                    eye.offset!([0, 0, 1.5.m])
                    That will lift the eye-level of the camera up by 1.5 meters, or whatever you add...
                    • C
                      ceci777
                      Hi we have using this tool for many years but found it have compatibility problem with sketchup 2019 , the "section cut plane" wont be generated after using so the view wont be "locked like what it should be in new version sketchup . don't know if it can be resolved as its really a good tool for generate elevation view in sketchup . thanks
                      • TIGT
                        I think you a muddling this up with SectionCutFace ?
                        In v2019 there's an auto-face option for Styles which is not editable.
                        Check that you Style has that un-ticked...
                        • C
                          ceci777
                          Hi, thanks for reply , i did not muddling this with sectioncutface .
                          Normally a " section cut plane " will be generated when making a section in sketchup and the physical " plane" available to be turned on and off .
                          It works in 2018 version and before version when i use this plugin to generate elevation scene , but problem come out after i upgraded into SketchUp 2019 .
                          After i use this plugin generate section cut scene , the " section cut plane " is not be created , and the model displayed crashing when i orbit. 😠
                          • TIGT
                            I think I now understand your issue better...
                            Whether a section-plane appears in a scene-tab or not, is controlled by each scene-tab's settings.
                            If if is set up right it should show the section-cut in the newly added elev-tag scene tabs - which will have been copied from the tab's settings current when they get made...
                            To add a missing section-cut to a elev-tag's new scene-tab you simply need to activate the section cuts' visibility and activate the desire cut [then hide the scene-tabs], then remember to update the relevant section-tab to see the section.
                            You scene setting's can be set up to NOT copy many settings over, check yours are set up as you need them...
                            I don't that this has ever been more 'automated' in this toolset...
