    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] TIG-ElevTag v1.0 20130603
    12 Posts 8 Posters 12.3k Views 8 Watching
      (c) TIG 2013
      All rights reserved.
      TIG-ElevTag.rb
      Loads Extension TIG-ElevTag.rb from ../Plugins/TIG-ElevTag subfolder
      Requires the component ElevTag.skp [v7] in the same subfolder.
      Usage:
      From right-click context-submenu only: 'ElevTag...'
      'Add...'
      This lets you place an 'ElevTag' instance in your model.
      Then you can Move/Rotate it as desired.
      Its initial state is with all 4 pointers shown [ABCD] and the 'Refs' = 1 and 2.
      When you select another tool [say Select <spacebar>] to complete the
      placement/adjustment then a dialog opens.
      This is the same dialog as if later you had selected an 'ElevTag' and used the
      context-submenu and chosen...
      'Edit & Scene-Tab...'
      Note: this only appears if an 'ElevTag' instance or equivalent group is selected.
      This opens a dialog that will let you set its:
      =Type : the ABCD arrows to display - all the permutations of the 1/2/3/4 arrows,
      the initial default = 'ABCD'.
      =Ref 1: the text in the top part of the circle - default = '1'
      =Ref 2: the text in the bottom part of the circle - default = '2'
      keep to 1 to 5 characters, to keep within the circle...
      =Show 'ABCD' ? : to control visibility of the Arrow text 'A' etc, Yes|No,
      [initial default = Yes]; useful with single arrows where it'd be superfluous,
      so s Single-Arrow's Scene-Tab Name will not include the ElevTag's 'Type' letter
      if 'Show?' is set to 'No'. Multiple-Arrow Scene-Tabs Names always include the
      'type' letter even when 'Show?' is 'No' because otherwise they cannot be
      named separately.
      =Target Distance: [in current-units] controls the initial zoom size
      [you can always zoom in/out later and update the Scene-Tab],
      a smaller distance == a closer zoom.
      =Click OK and the initial ElevTag Instance is converted into a Group
      [unless it is already one and you are now editing it later on], this Group is
      named after the Options e.g. 'ElevTag-AC-1-2.3'
      and the chosen Options are then effected.
      =Click Cancel NOT to change Options.
      A second dialog then asks if you want to make Make the Scene-Tabs for each of
      the Arrows:
      Yes: to Make it.
      No: to Skip it.
      If 'Show?'=='No' then Single-Arrow ElevTag Scene-Tab's Name will not have the
      'Type' letter, e.g.
      Elev-1-2.1
      If 'Show?'=='Yes' then Single-Arrow ElevTag Scene-Tab's Name will have the
      'Type' letter, e.g.
      Elev-A-1-2.1
      All Multiple-Arrow ElevTag Scene-Tabs' Names will always be prefixed with their
      'Type' letter, irrespective of the 'Show?' setting:
      Elev-A-1-2.3
      Elev-B-1-2.3
      etc...
      If a Scene-Tab already exists with a specified 'Name', then the dialog is
      different - it warns you and offers:
      Yes: to Change it.
      No: to Skip it.
      Cancel: to Abort the Operation and Change the ElevTag Options in a reopened
      dialog.
      Note how the dialog's last used Values for the ABCD, Show?, Target etc are
      reused during that session.
      Never rename an 'ElevTag-...' Group as it will no longer be recognized for
      Editing etc...
      Never edit an 'ElevTag-...' Group and delete entities within it, as I then won't
      work properly...
      Never change the contents of the 'ElevTag' SKP in the tool's subfolder.
      = v8 only.
      Donations: PayPal.com info @ revitrev.org
      Version:
      1.0 20130530 First release.
      Available for download at the 'SCF PluginStore'
      http://sketchucation.com/resources/pluginstore?pln=ElevTag
      Or for AutoInstall from the 'SketcUcation Plugin Store' dialog from within SketchUp itself...
      http://sketchucation.com/resources/plugin-store-download
        Ben Ritter
        TIG, thank you for another one. You are very generous.
        • KrisidiousK Offline
          Krisidious
          ๐Ÿ‘ Likes this... ๐Ÿ‘
          ๐Ÿ˜
          By: Kristoff Rand
            sepo
            ๐Ÿ‘
              tald311
              This looks promising and needed. Thank you!!
                JuanV.Soler
                very cool and handy TIG
                many thanks
                  RodolfoST
                  Hi! This plugin is exactly what I was looking for. Thank you!
                  Is it possible to place the solid section on the walls? I also noticed that the view is at the tag level. I think it would have been better if the view was positioned 1.5m above the tag.
                    To try this yourself... open the file ../Plugins/TIG-ElevTag/TIG-ElevTag.rb
                    Use a plain-text editor like Notepad++ or TextWrangler.
                    Find line #266 [it reads " up=tr.zaxis"] and insert a new line after it, with this text:
                    eye.offset!([0, 0, 1.5.m])
                    That will lift the eye-level of the camera up by 1.5 meters, or whatever you add...
                      ceci777
                      Hi we have using this tool for many years but found it have compatibility problem with sketchup 2019 , the "section cut plane" wont be generated after using so the view wont be "locked like what it should be in new version sketchup . don't know if it can be resolved as its really a good tool for generate elevation view in sketchup . thanks
                        I think you a muddling this up with SectionCutFace ?
                        In v2019 there's an auto-face option for Styles which is not editable.
                        Check that you Style has that un-ticked...
                          ceci777
                          Hi, thanks for reply , i did not muddling this with sectioncutface .
                          Normally a " section cut plane " will be generated when making a section in sketchup and the physical " plane" available to be turned on and off .
                          It works in 2018 version and before version when i use this plugin to generate elevation scene , but problem come out after i upgraded into SketchUp 2019 .
                          After i use this plugin generate section cut scene , the " section cut plane " is not be created , and the model displayed crashing when i orbit. ๐Ÿ˜
                            I think I now understand your issue better...
                            Whether a section-plane appears in a scene-tab or not, is controlled by each scene-tab's settings.
                            If if is set up right it should show the section-cut in the newly added elev-tag scene tabs - which will have been copied from the tab's settings current when they get made...
                            To add a missing section-cut to a elev-tag's new scene-tab you simply need to activate the section cuts' visibility and activate the desire cut [then hide the scene-tabs], then remember to update the relevant section-tab to see the section.
                            You scene setting's can be set up to NOT copy many settings over, check yours are set up as you need them...
                            I don't that this has ever been more 'automated' in this toolset...
