    Exporting Guidelines
    3 Posts 3 Posters 339 Views 3 Watching
    • S
      Shpox
      Hi Guys. Just a very quick question. I'm wondering if it's possible at all to export guidlines or even convert them to ordinary linework. I've looked inside the .dwg/dxf and .eps dialogues but nothing is quite there that works.
      Thanks in advance!
      • thomthomT
        http://sketchucation.com/forums/viewtopic.php?t=31225#p274567
        • TIGT
          In Pro when you Export a 3d DXF or DWG there is an options button on the dialog.
          This opens an options dialog in which you can specify what will be included in the exported data.
          One item is 'Construction Geometry' [aka Guide-lines and Guide-points] by default I think this is unchecked...
          Check it and they export as XLines/Rays and Points in the CAD version...
