Greater version of SU
Curviloft, Fredotools, need a greater version 6 up
error loading greeble_2, offset.rb,pushandpull group.rb
the courrent version is make 2013
the plugins aren't alredy upgraded to this version? but make 2013 ask me a version greater tha 6....
Screenshot of this message?
Are you using latest versions of these plugins?
Some plugins must be adapted!
I've not had problems with Fredo's tool though...
I'm getting the same error. I made sure that I had the permissions settings correct for the plugins and the tools folder.
I'm getting this error for Curviloft, Curvizard, FredoScale, FredoTools, Roundcorner, SUClock, ToolsOnSurface
Is version 13 too high a number for the plugins to recognize?
This is normally fixed with LibFredo6 4.8 and 4.9.
So please install the latest version.Fredo
Greeble has an updated version on the Extension warehouse. You should delete the version you have and install the new one on the EW. Also delete offset.rb if no other plugins are using it. It was used in greeble, but no longer is needed. I'll be updating the versions of my plugins on smustard and here hopefully sometime this week when I get a chance to breath again
I'm not sure about group_pushpull though.
I seem to recall running SU in Administrator mode solved some of these issues. Although, having updated everything, I can now run all my installed scripts without resorting to that. Might be worth a try for those still experiencing problems.
Thanks! I installed the latest version and that solved it!
Good to hear!
installed new version, Greeble is not free plugin now? I don't find where i can download it
I don't remember the plug in that use Mr Sonder for close the section when apply the section plane, so the section is not open but closed, someone remember the plugin name?....
Hi pier, greeble is available on the EW. Just look under my name and it will be listed there. Or you can also still get it from Smustard where its been hosted for years.
I'm sorry I can't help with the other plugin though, I"m not sure which one Sonder uses.
@pier70: TIGs SectionCutFace? I believe that's one.
Yes it si, thank u Tim, and thank u Chris
Register LoginAdvertisement
