    Greater version of SU
    14 Posts 8 Posters 1.3k Views 8 Watching
    • davids90gtD
      davids90gt
      I'm getting the same error. I made sure that I had the permissions settings correct for the plugins and the tools folder.
      I'm getting this error for Curviloft, Curvizard, FredoScale, FredoTools, Roundcorner, SUClock, ToolsOnSurface
      Is version 13 too high a number for the plugins to recognize?
      • fredo6F
        This is normally fixed with LibFredo6 4.8 and 4.9.
        So please install the latest version.
        • Chris FullmerC
          Greeble has an updated version on the Extension warehouse. You should delete the version you have and install the new one on the EW. Also delete offset.rb if no other plugins are using it. It was used in greeble, but no longer is needed. I'll be updating the versions of my plugins on smustard and here hopefully sometime this week when I get a chance to breath again 😄
          I'm not sure about group_pushpull though.
          • Alan FraserA
            Alan Fraser
            I seem to recall running SU in Administrator mode solved some of these issues. Although, having updated everything, I can now run all my installed scripts without resorting to that. Might be worth a try for those still experiencing problems.
            3D Figures
            • davids90gtD
              davids90gt
              Thanks! I installed the latest version and that solved it!
                Good to hear! 😄
                • P
                  pier70
                  installed new version, Greeble is not free plugin now? I don't find where i can download it
                  I don't remember the plug in that use Mr Sonder for close the section when apply the section plane, so the section is not open but closed, someone remember the plugin name?....
                  • Chris FullmerC
                    Hi pier, greeble is available on the EW. Just look under my name and it will be listed there. Or you can also still get it from Smustard where its been hosted for years.
                    I'm sorry I can't help with the other plugin though, I"m not sure which one Sonder uses.
                    • mitcorbM
                      mitcorb
                      @pier70: TIGs SectionCutFace? I believe that's one.
                      • P
                        pier70
                        Yes it si, thank u Tim, and thank u Chris
