    New Pattern Fill feature in Layout
    layout
    29 Posts 12 Posters 11.1k Views 12 Watching
    • MsketcherM
      Msketcher
      Has anyone played around with the new pattern fill feature in Layout? I'm trying to find the documentation on how it's intended to be used. I've got a couple questions and I'm wondering if anyone has figured this out yet.
      • Seems like patterns can only be applied to shaped created in Layout, Unless you convert a Sketchup model to Vector and explode it(So Layout recognizes it as a shape). But then you lose the ability to update the model. 😞
      • How do you delete a pattern? I can change it to a new pattern but can't figure out how to delete it all together. EDIT - I think I figured it out. You click on "Shape Style" and toggle the "Pattern" button off.
      I guess that's it. Any other tricks I should know about?
      • FrederikF
        Frederik
        Have you checked A closer look at LayOut...?
        Cheers
        Kim Frederik
        • sfto1S
          sfto1
          In the above link, all I can see is what they added, but not how to use. Are there any video tutorials for the new LO features?
          Or any videos explaining new features?
          • A
            ArCAD-UK
            I've played with it and I think it should save me a fortune in coloured ink and help me better differentiate areas. Upgrade cost covered. 😆
            • KrisidiousK
              Krisidious
              Would this help? arail1
              http://sketchucation.com/forums/viewtopic.php?p=341461#p341461
              By: Kristoff Rand
              • arail1A
                arail1
                My version of AutoCAD LT (2010) doesn't have backgrounds for hatches. The workaround (which never really works) is to have a solid color hatch for the background and then a pattern hatch on top. But you have to fight with AC to keep the order correct. PITA!
                Maybe this will warm me to the upgrade. Although I do wish this functionality existed on the SketchUp side of the fence rather than the Layout side.
                edit: I'm not warmed. Am I correct in thinking that this only works for shapes drawn in Layout? You can't apply patterns to the SkechUp model? What the ....!?
                • A
                  ArCAD-UK
                  The patterns are alpha PNG files. You can do the same thing in SU through materials application. The slight disappointment depending on what you want to do is the LO patterns aren't vector fills which could then be easily exported to DWG. As an addition to LO the patterns do help with different textures which you may want to vary from the SU model.
                  • jolranJ
                    jolran
                    Should I continue development further you think ?
                    Yes, noticed that to. This tool already excisted in TIG's 2dtools ?
                    (I'll try to stay objective since I'm developping a plugin for hatching).
                    PROS:
                    I think if one stay inside the Sketchup-Layout domain, and can accept the fact that one cannot alter the linethickness in hatches. I do think it is a very nice new feauture of Layout. It may do for most people, and I thinking of dropping my plugindevelopment(OT).
                    CONS:
                    If I'm not misstaken one have to draw the fill-shapes oneself. It would be helpful if hatching was a separate tool detecting boundaries(like a face) but that might be to much to ask for. (one can explode stuff, but.... 👊 )
                    Given that, it is still much faster to texture all faces(from a TIG sectioncutface for ex) in Sketchup and import that into Layout instead of drawing new shapes and pattern them.
                    Just my point of view.. I'm happy Layout getting some attention in this update.
                    • KrisidiousK
                      Krisidious
                      True, however you can't change to vector and keep the hatch. And personally I don't want to hand build a hatch and then have to modify it once I get to Layout.
                      By: Kristoff Rand
                      • G
                        Gjenio
                        That´s also my point of view and that of many architects out here.
                        It´s an incredible waste of time drawing point by boint the hatch over the walls in LO. Let´s just think about how much time it takes for a complex Plan, I don´t even dare think if in the same Plan constant changes occur... Nonsense!
                        TIG Sectioncutface still do the job better and quicker!
                        • KrisidiousK
                          Krisidious
                          you don't have to draw point to point... like other parts of SU and Layout, I have found that if you believe there should be a method for something there normally is.
                          When needing to hatch in Layout, import or "insert" your model, then convert it to vector, explode the group of vectored lines. use the "Glue" tool to merge lines into one continuous line, then use the pattern tool to hatch the area. It's not a fill tool with ray tracing, but it works.
                          Otherwise your method of hatching in SU leaves you with only Raster Rendering in Layout.
                          By: Kristoff Rand
                          • jolranJ
                            jolran
                            I did try the exploding/gluing method like you mentioned and thought it took longer then actually drawing new shapes on top of sketchup geometry, sometimes. And it's also a destructive method.
                            But nevertheless it's a good solution too. And I guess what works best depends on what kind of geometry one is dealing with.
                            LO 2013 is pretty new. I'm sure after some time there will some nice new workflow ideas
                            that will improve things.
                            • KrisidiousK
                              Krisidious
                              It is and I find it quicker to draw new ones as well... Whatsmore I can keep hatching on a separate layer than linework which is also convenient.
                              This as well as the dimension style is a little convoluted.
                              By: Kristoff Rand
                              • arail1A
                                arail1
                                I have not had time to download the plugin, maybe over the weekend. But, in general, yes you should continue development. In an area like this where none of the available solutions are real solutions, any new ideas would be welcome.
                                None of the workarounds would be applicable to me, much as they're appreciated. If you're looking to produce one finished set of drawings then exploding and rebuilding, etc. might work but I sit between the designers and the fabricators. My drawings can easily go through half a dozen major revisions in a day. That's why I'm always forced to go back to AutoCAD from SketchUp. Annotations and hatches in SketchUp are way too primitive to have a place in my workflow.
                                That's why I'm learning Rhino - Rhino has a modeling environment that's similar to SketchUp but with real annotations and hatches. The hatching and annotation aren't yet at the level of functionality that AutoCAD has achieved but it's much further along than SketchUp.
                                • K
                                  kaas
                                  Please do. For me as an architect real hatches in SketchUp are way better than those in LayOut:
                                  1. they can be exported to third party programs
                                  2. SU line-hatches in LayOut are much more crisp lines (no jaggies)
                                  3. if I draw a section in SU and apply real hatches in SU those two are re-used multiple times in LayOut: once for the section 1:100 and fragments of the same section multiple times as details scale 1:10
                                  Doing the hatches in LayOut is a no-go for me because of nr 3) If I would have to make changes I would have to do them on multiple parts in LayOut which would increase the risks of forgetting something / making errors etc.
                                  Greetings
                                  Max
                                  edit: quote-code went wrong
                                  • jolranJ
                                    jolran
                                    Point taken, I'll continue development then 😄
                                    It may delay though, working on some other stuff right now.
                                    Thanks for showing interest.
                                    /Joel
                                    • KrisidiousK
                                      Krisidious
                                      1. SU line-hatches in LayOut are much more crisp lines (no jaggies)
                                      New Layout Hatch does not have "Jaggies", The old Raster Imports of SU models do.
                                      By: Kristoff Rand
                                      • K
                                        kaas
                                        Absolutely wonderful. Highly appreciated! The process of hatching 2d sections of buildings would take a fraction of time with a plugin like the one you are developing (doing it by hand at the moment). The screenshot http://sketchucation.com/forums/viewtopic.php?f=323&t=38637&start=270#p365946 you released some time ago already made me drool 😄
                                        greetings, Max
                                        • MsketcherM
                                          Msketcher
                                          I guess I'm just missing the point of the pattern/hatching tool in Layout, if you can only use it on shapes created in Layout. If you wanted to hatch a model that you brought in, you'd have to explode it which would eliminate the ability to update the model.
                                          I guess I just don't use Layout shapes too much, so I've never had a need to apply hatching to them. Most of what I put in Layout are Sketchup models and annotations, so I'd just apply hatching as a material in Sketchup.
                                          Confused...
                                          • KrisidiousK
                                            Krisidious
                                            Confused...
                                            The main reason I do it it is because with your method you are left with raster images and not vector lines. I want vector.
                                            By: Kristoff Rand
                                            • 1 / 2
