    SketchUp 2014 Wishlist
    125 Posts 54 Posters 49.8k Views 54 Watching
    • studio43S Offline
      studio43
      Would like to see grips function added to line segments, in order to grab a line at the end or mid point for quick edit of line work
      • Y Offline
        Yishmeray
        I am sorry that I am very late to this party, not least because 2014 is already out!
        But in case it matters - you can open multiple models under windows, and have been able to do so as long as I can remember (at least since SketchUp 6). It's not perhaps in the obvious way (from sketchup use file -> open while another model is already open) but it works all the same - just double click a model file while another is open.
        • P Offline
          pibuz
          Has anybody mentioned a better system to handle SketchUp materials? Some sub-folder-ing system, or something more customizable would help a lot, much better than a simple list of used materials..
          Another dream of mine is support for reversible operations, such as dinamic redistribution of elements over a line, or different patterning of 3d-generated meshes without re-doing it (floor planks e.g.)..
          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
            ArtPen
            Have been working in sketchUP on a couple of complex architectural and landscape project just now and thought it will be worse to update a wish list.
            GENERAL
            1A. Xref or other proper Reference system with Project folder setup.
            So you can see all References in the Master model and been able to open them start from the master model make changes in separate file,
            then save and update the master model
            1B. Some kind of team work please
            1. X64 for big complex project
            2. Texture folder. Each SketchUp file will have a separate Texture folder inside a project folder. To keep all organise.
            3. Faster Viewport using modern OpenGL technologies. Nice representation , colours , anti-aliasing , soft shadows, nicer fog and light.
            4. Groups for Layers
            5. High Quality Google Maps with option to grab bigger locations
            6. X64 and FASTER Layout
            7. I think it is time to introduce wall, slab, window/door, curtain wall, elements
            8. Components to be able to cut through walls ( two faces )
            9. Better lines and curves. Able to see centre point of each curve. Able to see tangent points.
            10. Line types (without using plugin)
            OSX
            1. Material list
            2. Show total area of material in a model by right click on the material inside the material browser. Yo can do it on Windows
            3. Better UI
            4. Full screen
            Just wanted to ask is there any official way to submit our wish lists to Trimble directly? Of cause they work hard to deliver better program but they quite close from the community.
            Updates are very rear. No information is given unfortunately .
            Cheers
              Looks like your in the wrong wishlist...SketchUp 2014 is out nearly 12 months.
              • 6
              • 7
              • 7 / 7
