How Can i have thicker lines in sketch up?
I am using sketchup draw to draw floor plans. and the default lines are too thin for print. how can i create heavy lines?? thanks
You can control the appearance of lines in the styles menu. under the Edit tab. the fist sub-sub menu is the square box with only lines.
Or may I suggest TIGs 2D tools. (which I have only just discovered myself, Thank you Tig)
http://sketchucation.com/forums/viewtopic.php?f=323&t=22091&hilit=2d+toolsI hope this is of help
thanks. i downloaded for my sketchup mac. it keeps freezing though. maybe i didn't download the proper updated version.
Maybe you didn't install it correctly. I have 2D Tools on my Mac and it works perfectly.
