    Texture Mapping Curtains
    28 Posts 8 Posters 4.7k Views 8 Watching
    • Gus RG
      Gus R
      @rich o brien said:
      Are you using SketchUV Gus?
      Did you explode the model to remove it default axix position?
      Did you remove the mats applied to the group and not the geometry?
      Opened the skp. Removed the material from the group. One iteration of Artisan smoothing. Applied material. Exported UV with SketchUV within the group not moving or having rotated anything. Imported obj into Blender. Scaled it down. Right click and smooth. Tabbed into edit mode and click U and then UV unwrap. Then I switch over to texture mode and it's at 45 degrees. Tried it again with a fresh download of the skp in case I moved anything earlier.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        @Gus
        In the UV editor hover over the unwrapped mesh and press L to select it
        R to rotate it
        If you can give me a link to that cloth as I can't find it now...so I can investigate it.
        I'm sure I'm missing something here
        • Gus RG
          Gus R
          @rich o brien said:
          @Gus
          R to rotate it
          Thanks, was practicing the rotation as well. Reset Blender to factory settings as well. Here's the link to the model.
            So, here's my result
            Exploded SU model
            removed texture
            sub'd
            applied mat to front face
            selected all export UVs
            imported into Blender
            scaled down
            tabbed into edit mode
            U to unwrap and here's the results
              @Gus
              Looking at this again there is some stray geometry getting unwrapped
              http://sketchucation.com/forums/download/file.php?id=105623&mode=view/rokbox.jpg
              you can see it in the bottom right corner
              • Gus RG
                Gus R
                @rich o brien said:
                @Gus
                Rich, I found a fix by uninstalling Blender 2.63 and upgrading to 2.67. Works now. Thanks for your help.
                • jo-keJ
                  jo-ke
                  ah, these decorated curtains a very difficult. If had the same problems too and they aren't solved yet.
                  Below I attach my file, for trying to texture with vertical stripes...
                  raffschal.skp
                  http://www.zz7.de
                    D'oh!
                    Never cross my mind you were on an old version. Happy mapping
                    • 2 / 2
