    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 779.7k Views 143 Watching
      Slagothoric
      Fredo, thank you so much for addressing my issue. That is truly some amazing support. Please include your preferred link and I will gladly donate for your efforts!
        @slagothoric said:
        ...Please include your preferred link and I will gladly donate for your efforts!
        Many authors provide a 'Donate' link-button [yellow] on their PluginStore entries listings...
        • E Offline
          edarchm2
          where ccan i download it?#
          • fredo6F Offline
            fredo6
            You can download the RBZ at https://sketchucation.com/pluginstore?pln=TopoShaper
            Note that you need to install also the companion library LibFredo6.
            Otherwise, the best is to install the Sketchucation ExtensionStore plugin and then auto-install TopoShaper and any of the 800 plugins in the store in one click.
            Fredo
              rv1974
              Hi Fredo,
              *) How do I solve 'needle eye' obstacle (see attached)? Plugin get stuck at this stage forever.
              *) Second very primitive mesh crashes on generating. Could you take a look at this example?
              P.S. I always had scruples to ask, What is purpose of this 2nd 'zoomed' mesh in beige square?
              Untitled.skp
              • fredo6F Offline
                fredo6
                @rv1974 said:
                Hi Fredo,
                Your models seems 'unprepared' for TopoShaper. I don't see contour lines, but instead lot of edges with intersections and different altitudes.
                The blocking on Needle Eye is actually just a Ruby error due to the convoluted configuration of contours, but even if I fixed it, I don't see how you can generate a terrain from your input data.
                Fredo
                  rv1974
                  RTFM helped as usual, many thanks
                  • PixeroP Offline
                    Pixero
                    I was wondering if there is a limit to how detailed a ISO lines terrain can be to work with Toposhaper?
                    As you can see in the attached image only a part of the terrain is created. If I try with a less dense contour file of the same area it works but I need the detail as high as possible.
                    • fredo6F Offline
                      fredo6
                      [attachment=0:2s5end60]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2s5end60]
                      The typical usage of TopoShaper is to smooth out the terrain, using isocontours as guides for altitude. The precision of the contours is not necessary (i.e. does not need closely spaced contours, nor many points in the contour curves), and anyway in relation with the resolution of the mesh.
                      All this being said, I am impressed by the large model you have.
                      Fredo
                        clement duvoux
                        Bonjour Fredo,
                        Après installation de la dernière version de Toposhaper (2.3b) et de LibFredo6 v8.1h, Toposhaper ne s'execute pas à l'ouverture de Sketchup, renvoyant un message d'erreur qui est le suivant : "you must install LibFredo6 to run Toposhaper
                        Open the download page of LibFredo6 at https....".
                        Après vérification dans l'extension manager, LibFredo est pourtant bien installé. Une idée sur l'origine du bug ?
                        • fredo6F Offline
                          fredo6
                          @clement duvoux said:
                          Bonjour Fredo,
                          Il faut verifier que LibFredo6 est bien chargé. Est ce qu'il y a un menu Window > LibFredo6 Settings.... ?
                          Fredo
                          • G Offline
                            gio
                            [attachment=0:1bzib748]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1bzib748]
                            Maybe you can make just smaller portions and join them in the end?
                            Gio
                              dlannetts
                              Hello,
                              Great plugin, however I am having an issue, after generating the terrain from guide points, using the toolbar, and clicking off elsewhere, the toolbar disappears and I can't seem to get it back to modify the terrain. How can I get the toolbar back after it has disappeared?
                              David.
                              • fredo6F Offline
                                fredo6
                                @dlannetts said:
                                Hello,
                                David.
                                Can you open the Ruby console, as there may be an error.
                                Did the terrain generate correctly by the way?
                                Fredo
                                  simonhaufe
                                  I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
                                  Any ideas and suggestions are most welcome!! 😎 ☀
                                  Best Regards Simon
                                  • fredo6F Offline
                                    fredo6
                                    Best Regards Simon
                                    I don't think TopoShaper can handle 130,000 points; and I don't think either that Sketchup will not scream with a mesh of 130,000 vertices.
                                    So you'll probably have to find a way, with other tools to simplify the input points or raw mesh, either simplifying, or cutting in pieces if the cloud covers a very large area. I don't know if there are Ruby scripts in Sketchup to do that, but I know there are specialized terrain software that can do it. There are several discussion threads in Sketchucation and Sketchup forums about terrains.
                                    Fredo
                                      rspierenburg
                                      I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
                                      Toposhaper Error
                                      • fredo6F Offline
                                        fredo6
                                        It would be helpful that you attach your model so that I can investigate. Thanks.
                                        Fredo
                                          rspierenburg
                                          Thanks, Here is the model.
                                          Topography.skp
                                          • fredo6F Offline
                                            fredo6
                                            @Rspierenburg
                                            You just need to put all contruction points and the contour within a Group, then select the group and run TopoShaper Cloud.
                                            Note that your model seems to have some points which create peaks.
                                            Fredo
                                            Rspierenburg - Topography - SU2015.skp
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
