SU2KT plugin not opening kerkythea automatically
hi
I have just installed sketchup and kerkythea on a new computer and added the SU2KT plugin.
Having a problem in that kerkythea will not open automatically. I have to go to the .xml file and open from kerkythea. It's a small problem but rather annoying.
When i click on the plugin icon it goes trough the usual process but when it comes to opening in kerkythea a message comes up saying that it will not open automatically and to change permissions in the file folder.
The thing is that i don't know how to do this!
Can anyone help?
Find the folder relating to that message.
Select its icon.
Right-click > context-menu > Properties > Security > Edit
Give everyone listed FULL permissions
OK and close to effect the changes.You will need to have admin-rights to do this...
If you don't, then set that aspect up in the Users Control Panel first... -
Thanks for the tip, I've had the same problem.
Thanks TIG for your help. Unfortunately the computer in question had a bit of a meltdown and had to be returned.
Installed kerkythea on new system with no problems.
Thanks again for response.
Register LoginAdvertisement
