    SU2KT plugin not opening kerkythea automatically
    4 Posts 3 Posters 672 Views 3 Watching
      RAGraphics
      hi
      I have just installed sketchup and kerkythea on a new computer and added the SU2KT plugin.
      Having a problem in that kerkythea will not open automatically. I have to go to the .xml file and open from kerkythea. It's a small problem but rather annoying.
      When i click on the plugin icon it goes trough the usual process but when it comes to opening in kerkythea a message comes up saying that it will not open automatically and to change permissions in the file folder.
      The thing is that i don't know how to do this!
      Can anyone help?
        Find the folder relating to that message.
        Select its icon.
        Right-click > context-menu > Properties > Security > Edit
        Give everyone listed FULL permissions
        OK and close to effect the changes.
        You will need to have admin-rights to do this...
        If you don't, then set that aspect up in the Users Control Panel first...
          JGA
          Thanks for the tip, I've had the same problem.
          Regards,
          JGA
            RAGraphics
            Thanks TIG for your help. Unfortunately the computer in question had a bit of a meltdown and had to be returned.
            Installed kerkythea on new system with no problems.
            Thanks again for response.
