    [REQ]Diagonalization
    6 Posts 4 Posters 536 Views 4 Watching
    • Y
      yannleo
      Anyone knows how to diagonalize a quad mesh in SketchUp like this?
      • BoxB
        How about Triangular quad faces by Tig
        http://sketchucation.com/forums/viewtopic.php?t=23638
        • Y
          yannleo
          It's not diagonalization.You may find that its like this:
          • TIGT
            BUT... then you can select the facets [leaving the lowest ones unselected], Rotate tool locked flat with shift-key and snapped to top apex, rotate them by a suitable angle [depends on the number of segments in the original circle] - or snap rotate vertex to midpoint.
            Then deselect the lowest selected facets etc, repeat the rotation step... repeat this until all of the facets are rotated and the facets' angles are all 'equilaterals'...
            • cottyC
              cotty
              One subdivision with Artisan...
              my SketchUp gallery
              • Y
                yannleo
                hi,TIG,thanks for your reply. It could work for a regular shape like sphere or cylinder. If I have more complex geometry it's hard selecting specific edges one by one and rotate them. I think there must be a sort of algorithms to firstly divide mesh by hexagons or diamond pattern and then subdivide it in triangles.It could be convenient if there is ruby code, instead of using other program.
