    [Plugin] Qpik::SimpleRays v1.0.1
    13 Posts 7 Posters 19.1k Views 7 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Qpik::SimpleRays
      Jakub Kupikowski (qpik) is not a programmer, so I overhauled
      his plugin so it can be removed from the Quarantine List.
      (For more info see old post: Ambient Occlusion -> Simple Rays.)
      BEFORE INSTALLING, DELETE the old file "simple_rays.rb"
      Qpik_SimpleRays_1_0_1.rbzv 1.0.1 : 2013-01-05
      Corrected @@lang assignment in language file rescue block.
      simple_rays.rb: lines 109 and 111
      @@lang == 'en' %(#008000)[# just use English]
      should be making an assignment:
      @@lang **=** 'en' %(#008000)[# just use English]
      See Developers forum: [Talk] Qpik::SimpleRays Overhaul
      Notes:
      • All code within the Qpik::SimpleRays namespace
      • No longer modifies Ruby nor API classes.
      • Now cleanups the temporary image files and dirs after itself.
      • Remembers inputbox entries during the session
      • commented out the purge all materials
      • multi-language
      What I did not do:
      • Re-write methods for optimization
      πŸ€“
      I'm not here much anymore.
      • renderizaR Offline
        renderiza
        Thank you so much for this!
        Maybe in the future if I learn enough I'll try to make a plugin with couple render features and Ambient Occlusion is really useful to have.
        Cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          Dan Rathbun
          Well I only fixed it (proper namespacing, etc.)
          • U Offline
            unclex
            It's Wonderful
            but how to use it
              Dan Rathbun
              @unclex said:
              ... but how to use it
              For more info see old post: [Info] Ambient Occlusion -> Simple Rays.
              • masterpaulM Offline
                masterpaul
                If this works with texture.... omg.
                Edit1:
                Downloaded.. works well, one step closer to baked lightning in sketchup. However I wish I could bake the lightning on to textured surfaces. This plugin has the potential to be amazing.
                Ill run a few tests and post them here
                Edit 1:
                Plugin crashes a lot on 10/10 settings. On a light geometry model.
                Edit 2
                Well the plugin crashes on models other then simple boxes, it also has problems with curves. I guess it still needs a lot of work.
                  Dan Rathbun
                  It is really at the conceptual stage.
                    crafty1980
                    How do I install this? I've moved the rbz file into the plugins directory but nothing appears in the program? Is it not compatible with SU2013?
                      Dan Rathbun
                      RBZ is simply a zipped archive that has had it's extension renamed to rbz.
                      What most people do is put them in a subdir of their downloads dir, named whatever you wish.
                      Mine is %(#004000)["<user path>/downloads/SketchUp/plugins"], but you name yours whatever you wish.
                      Then to install semi-manually, you go to:
                      Window (menu) > Preferences (dialog) > Extensions (panel)
                      Then click the Install Extension ... button.
                      A file broswer window opens. Browse to the location where you normally save your zipped plugins.
                      Hilite the one to install.
                      Click OK.
                      SketchUp unzips the plugin into the current SketchUp version's normal plugin directory. (The location varies from platform to platform, and version to version. ie, slowly resources are bing migrated to reside within the User's %AppData% [Windows] or "Application Support" [Mac] paths so as to avoid access permission issues.)
                      If you wish a more automated plugin experience,... install the SketchUcation Tools plugin manager, and install it via it's interface.
                      • Q Offline
                        qpik
                        I'm back. Any questions regarding the plugin are welcome.
                          Dan Rathbun
                          Welcome back, Jakub !
                            tamic
                            Hi Jakub and Dan,
                            I'd like to try it. What sketchup versions is this plugin compatible with?
                            I have installed it on 2016, and I can get only options context menu. No result anyway. How to fire an output image? Would it save somewhere onto hdd or display only in viewport? Best regards from Poland!
                            • Q Offline
                              qpik
                              tamic
                              I use it with SketchUp 7.0
                              It saves new textures either in the folder your model is saved or in a temporary folder and then replaces materials in the model so you should see it right away
                              I just started a similar project but using Blender https://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=67569
