    [Plugin] Qpik::SimpleRays v1.0.1
    13 Posts 7 Posters 19.4k Views 7 Watching
    • Dan RathbunD
      Dan Rathbun
      Thank you so much for this!
      Well I only fixed it (proper namespacing, etc.)
      I'm not here much anymore.
      • U
        unclex
        It's Wonderful
        but how to use it
        • Dan RathbunD
          Dan Rathbun
          @unclex said:
          ... but how to use it
          For more info see old post: [Info] Ambient Occlusion -> Simple Rays.
          • masterpaulM
            masterpaul
            If this works with texture.... omg.
            Edit1:
            Downloaded.. works well, one step closer to baked lightning in sketchup. However I wish I could bake the lightning on to textured surfaces. This plugin has the potential to be amazing.
            Ill run a few tests and post them here
            Edit 1:
            Plugin crashes a lot on 10/10 settings. On a light geometry model.
            Edit 2
            Well the plugin crashes on models other then simple boxes, it also has problems with curves. I guess it still needs a lot of work.
            • Dan RathbunD
              Dan Rathbun
              It is really at the conceptual stage.
              • C
                crafty1980
                How do I install this? I've moved the rbz file into the plugins directory but nothing appears in the program? Is it not compatible with SU2013?
                • Dan RathbunD
                  Dan Rathbun
                  RBZ is simply a zipped archive that has had it's extension renamed to rbz.
                  What most people do is put them in a subdir of their downloads dir, named whatever you wish.
                  Mine is %(#004000)["<user path>/downloads/SketchUp/plugins"], but you name yours whatever you wish.
                  Then to install semi-manually, you go to:
                  Window (menu) > Preferences (dialog) > Extensions (panel)
                  Then click the Install Extension ... button.
                  A file broswer window opens. Browse to the location where you normally save your zipped plugins.
                  Hilite the one to install.
                  Click OK.
                  SketchUp unzips the plugin into the current SketchUp version's normal plugin directory. (The location varies from platform to platform, and version to version. ie, slowly resources are bing migrated to reside within the User's %AppData% [Windows] or "Application Support" [Mac] paths so as to avoid access permission issues.)
                  If you wish a more automated plugin experience,... install the SketchUcation Tools plugin manager, and install it via it's interface.
                  • Q
                    qpik
                    I'm back. Any questions regarding the plugin are welcome.
                    • Dan RathbunD
                      Dan Rathbun
                      Welcome back, Jakub !
                      • T
                        tamic
                        Hi Jakub and Dan,
                        I'd like to try it. What sketchup versions is this plugin compatible with?
                        I have installed it on 2016, and I can get only options context menu. No result anyway. How to fire an output image? Would it save somewhere onto hdd or display only in viewport? Best regards from Poland!
                        • Q
                          qpik
                          tamic
                          I use it with SketchUp 7.0
                          It saves new textures either in the folder your model is saved or in a temporary folder and then replaces materials in the model so you should see it right away
                          I just started a similar project but using Blender https://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=67569
