    45 degree angle on a trim board
    14 Posts 7 Posters 4.3k Views 7 Watching
    • K Offline
      kghowell65
      Hi. I want to put a 45 degree cut on the end of a piece of 1x8 trim to wrap the framing on a deck. This would be for butting into another trim board at a corner. I'm sure it's east but I want to make sure I do it the correct way. Thanks
        Without image it's difficult to imagine excactly what you do want but...
        A funny method with the
        On any rotating volume πŸ˜„
        Now just PushPull the triangle πŸ˜‰
        http://tomastouch.fr/c/90-category/la-panthere-rose.jpg
          There are lots of ways to miter the ends of your 1x8s. Pilou has shown one although his would leave you with an open corner. πŸ˜‰ Here's another way.
          Select the edge of the board. This would be the edge at the corner that would drop on your foot when you saw the real board. Get the Move tool and...
          ...move the edge back along the face. a 1x8 should be 3/4 in. thick so move the edge 3/4 in. and you'll have a 45Β° miter. The move distance is the thickness of the board. No fuss, no muss.
          This method wouldn't work for a profiled molding but for the skirting around your deck, it'll be perfect. Do it on one skirt board component and copy that component around the deck to make the rest. Use Make Unique as needed so you can edit the length by selecting a mitered face and moving it to the desired length.
          • Jean LemireJ Offline
            Jean Lemire
            Hi Ken, hi floks.
            Click in sequence on the scenes tabs of this SketchUp file for ideas:
            Deck wrapping boards.skp
              TECHDAVE02
              Try this site
              (www.mastersketchup.com)
              • BoxB Offline
                Sometimes it is best to think about how you would do things in real life. To this end I made a mitre box. Although it's really only a bit of a joke, it is fully functional.
                Simply pop your wood in, adjust the saw to the correct angle, and use Intersect faces to create the cut you want. It won't fall off on your foot, you'll have to delete the bits you don't want, but it does create the "saw cut".
                The main thing is, it gives you a visual, and almost tactile, reference to the physical world which can help to bring your own physical skills into the virtual world.
                Think of it as an analogue plugin.
                Mitre Box.skp
                  (Maybe its the same solutions than Jean, I can't reload his version πŸ˜‰
                  With the V8 Pro you have also the solution of some boolean Diff operations!
                  your volumes must be "solids"
                  So just put a "big box" at 45Β° of your volume and make your cut! πŸ˜„
                  With free Coolean by OscarLok
                  • K Offline
                    kghowell65
                    Hi everyone. Thanks for all the great advice. Let me try out a couple and see what happens.
                      mics_54
                      shall we leave the poor man something to learn tomorrow?
                        πŸ‘
                          Jean Lemire
                          Hi Pilou, hi folks.
                          Sorry. Here in V6.
                          • K Offline
                            kghowell65
                            Thanks again to all. I tried DaveR's method and it worked great.
                              πŸ‘ Sometimes simple is best. πŸ˜‰
                                From Jean's example
                                Assuming you have 90Β° walls!
                                Split Sausage by Tig! πŸ˜‰
