    45 degree angle on a trim board
    14 Posts 7 Posters 3.8k Views 7 Watching
      TECHDAVE02
      Try this site
      (www.mastersketchup.com)
      • BoxB Offline
        Sometimes it is best to think about how you would do things in real life. To this end I made a mitre box. Although it's really only a bit of a joke, it is fully functional.
        Simply pop your wood in, adjust the saw to the correct angle, and use Intersect faces to create the cut you want. It won't fall off on your foot, you'll have to delete the bits you don't want, but it does create the "saw cut".
        The main thing is, it gives you a visual, and almost tactile, reference to the physical world which can help to bring your own physical skills into the virtual world.
        Think of it as an analogue plugin.
        Mitre Box.skp
          (Maybe its the same solutions than Jean, I can't reload his version πŸ˜‰
          With the V8 Pro you have also the solution of some boolean Diff operations!
          your volumes must be "solids"
          So just put a "big box" at 45Β° of your volume and make your cut! πŸ˜„
          With free Coolean by OscarLok
            kghowell65
            Hi everyone. Thanks for all the great advice. Let me try out a couple and see what happens.
              mics_54
              shall we leave the poor man something to learn tomorrow?
                πŸ‘
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi Pilou, hi folks.
                  Sorry. Here in V6.
                  Deck wrapping boards.skp
                    kghowell65
                    Thanks again to all. I tried DaveR's method and it worked great.
                      πŸ‘ Sometimes simple is best. πŸ˜‰
                        From Jean's example
                        Assuming you have 90Β° walls!
                        Split Sausage by Tig! πŸ˜‰
