    Face Issue
    9 Posts 4 Posters 520 Views 4 Watching
      luisfernando
      Guys, I am running into a problem and I don´t have the slightest idea how to solve that.
      The issue is as follows:
      When I select one specific face, the selection shows as if there were two faces. Even not having any edges separating them.
      Take a look at the image I attached here for a better understanding.
      Any kind of help is welcome.
      Thanks in advance.
      Face Issue
        And if you turn on Hidden Edges?
          luisfernando
          First of all, thank you Thom.
          Is this option the same as "Hidden Geometry"? If so, I already did that. But there no edges dividing the face. I don´t know why it´s splitted. 😕
            Yea, that's the one - I typed the name incorrectly.
            What about hidden layers?
            Can you upload a sample model?
              luisfernando
              For sure, in order to make the file smaller, I saved only one face which also has the same problem.
              Thanks man
              Face - Example.skp
                Yup! The edges where on layer 0.2 and 0.3a which where hidden.
                Note that layers doesn't separate or isolate objects, even though entities are on different layers they will still merge.
                  You wouldn't run into this sort of problem if you leave the edges and faces on Layer 0 as you're supposed to. 😉
                    luisfernando
                    Wow! I don´t understand why the hell sketchup does that. I mean, it creates a half face in one layer, and the another half in another. There´s no sense.
                    Thanks a lot guys, mainly Thom for the quick and eficient answers. (Dave too).
                      sonder
                      Actually Sketchup doesn't do that, you did. Always draw on layer 0. Once a layer is selected, all lines and faces created are on that layer. In this case you must have selected the layers or copied something from another file set to those layers.
