    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 77.1k Views 31 Watching
    • renderizaR Offline
      renderiza
      @anton_s said:
      I have tried to enclose some code with start and commit operations but even though its assigned name appears as a undo option it only does it one step at a time. ๐Ÿ˜ž
      Oh, just add model.start_operation(...) at the beginning of onLButtonDown method, and add model.commit_operation in the onLButtonUp method. After that, it must work ๐Ÿ˜„
      Btw, open Ruby Console and test your plugin; it has a bunch of tiny bugs ๐Ÿ’š
      The Add::Multiple does not work under "onLButtonDown" but instead under "onMouseMove" which seems not to work well with model.start_operation & model.commit_operation.
      I did test the model.start_operation & model.commit_operation with onLButtonDown and it worked but since you only add one object it doesn't need undo s that much.
      Thanks for pointing out the bug at Ruby Console!...I have to learn to Debug! ๐Ÿ’š
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • KrisidiousK Offline
        Krisidious
        Kool stuff... great for landscaping.
        By: Kristoff Rand
          renderiza
          Released Canvas 1.0.5 Beta includes;
          1.0.5 Beta:: 4/15/2013
          * Changed Web Dialog 'Frames Per Second' from 1 fps to 5 fps
          * Added Cursor Point Ref
          * Tooltips on ip1
          * Add:: On Shadow
          Notes:
          The frame rate that updates the values of Web Dialog is now little bit more responsive since I changed the fps from 1 to 5.
          Also added a red point under cursor so that its easier to see where you are placing objects. And there is even a tool tip that display text to inform on what you are on.
          And finally thanks to TIG I was able to solve the Add:: On Shadow so that you can place objects only o shadow.
          Again thanks for feedback and hope to add new things in the future!
          Hi, I am glad you found a use for it!
            renderiza
            1.0.6 Beta:: 4/19/2013
            * Plugin is portable friendly now
            This update makes the plugin portable for people that don't use the default plugins folder.
            Thanks to thomthom for suggesting doing this. ๐Ÿ‘
            • CadFatherC Offline
              CadFather
              Thanks Renderiza - a great plugin.
              1 question, is there anyway to avoid stacking objects on top of each other when free painting?
                renderiza
                The closes thing to address this is "Don't Add:: If pointer on top of face" check-mark but its suggested that the axis of the object is being use to pain is centered. Problem with the method I mentioned is that it only works if you are painting on empty surface and you might still have some staking here and there.
                I am still thinking to add a feature that solves this issue but until l then you might want to look at this...
                On http://sdmitch.blogspot.com/ there is a plugin called Component Check - Check for over-lap of given component removes one.
                Here is Direct link and video link...
                https://docs.google.com/file/d/0Bw8zdmaKDWIfNjgxYjAzNmYtNjQ0YS00ZTkwLThlYTMtNTMwZTFmNWZhZDJh/edit?pli=1
                Page Not Found
                Web word processing, presentations and spreadsheets
                (docs.google.com)
                Cheers! ๐Ÿ‘
                  CadFather
                  I see.. well it is quite amazing already - one of those 'unleash the creative' plugin (and thanks for the links). ๐Ÿ‘
                    renderiza
                    Canvas v1.0.8 Released!
                    Hi, this is small update to make plugin compatible with Extension Warehouse.
                      matt.gordon320
                      Hey Renderiza, great plugin so far, I'm excited to see what you come up with next!
                      Just wanted to give you a head's up that there's a little typo (components is misspelled) that shows up in the Status bar when you hover over the Canvas Icon.
                        Krisidious
                        Nice work Rafael...
                        By: Kristoff Rand
                          renderiza
                          Thank you!...that typo will be fixed for next version of Canvas. ๐Ÿ‘
                          @krisidious said:
                          Nice work Rafael...
                          Thank you very much! ๐Ÿ‘
                            renderiza
                            [pre:1th8ey5v]Authors:: Renderiza
                            Plugin Name:: Canvas
                            Version:: 1.9
                            Date:: 8/4/2013
                            Cost:: Free[/pre:1th8ey5v]
                            New Canvas Release!
                            %(#909090)[What is New!
                            • Random Rotation
                            • Random Scale]
                              ______________________________________________________________________
                            Web-Dialog
                            http://s13.postimg.org/dpwiv3kp3/canvas_1.jpg
                            • EdsonE Offline
                              Edson
                              it would be great to have a short video โ€“ like the ones Rich produces โ€“ to show all the plugin's funcionalities.
                              I am afraid it just does not work for me on mac. I tried selecting some components, not selecting, different input points, etc. nothing happens.
                              could anyone explain the correct workflow to make this plugin work?
                              edson mahfuz, architect| porto alegre โ€ข brasil
                              http://www.mahfuz.arq.br
                                renderiza
                                [pre:3o2qehfz]Authors:: Renderiza
                                Version:: 1.1.0
                                Date:: 9/25/2013
                                Cost:: Free[/pre:3o2qehfz]
                                Canvas v1.1.0 is now available for download.
                                %(#909090)[What is new:
                                • Smaller interface
                                • Tons of Bug fixes]
                                  renderiza
                                  [pre:1okaqzi0]Authors:: Renderiza
                                  Version:: 1.1.1
                                  Date:: 9/27/2013
                                  Cost:: Free[/pre:1okaqzi0]
                                  Canvas v1.1.1 is now available for download.
                                  • Bug fixes!]
                                  • halroachH Offline
                                    halroach
                                    @krisidious said:
                                    what is the difference between this and spray paint can?
                                    It looks very similar to Component Spray. So what are the differences?
                                    http://sketchucation.com/forums/viewtopic.php?p=298004#p298004
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                      renderiza
                                      There are couple differences but I guess the most significant is how each plugin choose to apply the objects. You can paint a single object at a time by left clicking with both plugins, but when it comes to applying multiple entities each extension have their unique ways of doing so.
                                      Canvas will spray multiple objects by clicking & holding the left mouse button so that when you move around it will paint.
                                      Component Spray has different shapes like line,triangle,square, ect. so the user draws with that shape and multiple object will spray according to that.
                                      Both support random scale & rotate feature and each of them have different type of filters for applying object.
                                      Note: I am currently working on Canvas for improving its web-dialog so keep an eye for future update
                                      Thanks!
                                        renderiza
                                        [pre:101ascxl]Authors:: Renderiza
                                        Version:: 1.1.3
                                        Date:: 10/12/2013
                                        Cost:: Free[/pre:101ascxl]
                                        Canvas v1.1.3 is now available for download.
                                          jpalm32
                                          Really clean polished work. Well done.
                                          • halroachH Offline
                                            halroach
                                            Very nice Renderiza!
                                            1. It would be great to have the ability to choose a bunch/list of components to paint, that alternate randomly or in a cycle - kinda like with the "component spray" plugin.
                                            2. An idea to think about... Having the ability to set a point in space that all blue axis of newly inserted components will align to. Like a magnet point.
                                            3. The ability to rotate objects randomly in all axis. Not only in the XY. Not sure what it would be good for... but it could be nice.
                                            • 3 / 5
