    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 83.7k Views 31 Watching
    • renderizaR
      renderiza
      **@guanjin said:
      (1) whether selecting the components out of the Options dialog box, select the function dialog box will disappear automatically affect the visibility of the window.
      (2)Select the function to maintain the next default.
      (3)Can achieve a variety of different components replication, scaling.
      Thank you!Do not mind if I just fantasy! πŸ‘**
      Thanks for the suggestions they really help. πŸ‘
      **@olishea said:
      Well done Rafael, looking forward to the plugin's progression.
      Thank you very much.**
      **@anton_s said:
      Nice plugin!! πŸ‘
      A suggestion:
      Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’**
      I have tried to enclose some code with start and commit operations but even though its assigned name appears as a undo option it only does it one step at a time. 😞
      **@driven said:
      Bug Fixed in Canvas
      I found a tutorial on how to do this with cookies so hope to make it happen soon
      this does it...
      ## @@canvas_dlg.set_position (70,95) ;
      john**
      What I meant was for plugin to remember form values like check boxes for example
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Anton_S
        Oh, just add model.start_operation(...) at the beginning of onLButtonDown method, and add model.commit_operation in the onLButtonUp method. After that, it must work πŸ˜„
        Btw, open Ruby Console and test your plugin; it has a bunch of tiny bugs πŸ’š
        • renderizaR
          renderiza
          The Add::Multiple does not work under "onLButtonDown" but instead under "onMouseMove" which seems not to work well with model.start_operation & model.commit_operation.
          I did test the model.start_operation & model.commit_operation with onLButtonDown and it worked but since you only add one object it doesn't need undo s that much.
          Thanks for pointing out the bug at Ruby Console!...I have to learn to Debug! πŸ’š
          • KrisidiousK
            Krisidious
            Kool stuff... great for landscaping.
            By: Kristoff Rand
            • renderizaR
              renderiza
              Released Canvas 1.0.5 Beta includes;
              1.0.5 Beta:: 4/15/2013
              * Changed Web Dialog 'Frames Per Second' from 1 fps to 5 fps
              * Added Cursor Point Ref
              * Tooltips on ip1
              * Add:: On Shadow
              Notes:
              The frame rate that updates the values of Web Dialog is now little bit more responsive since I changed the fps from 1 to 5.
              Also added a red point under cursor so that its easier to see where you are placing objects. And there is even a tool tip that display text to inform on what you are on.
              And finally thanks to TIG I was able to solve the Add:: On Shadow so that you can place objects only o shadow.
              Again thanks for feedback and hope to add new things in the future!
              Hi, I am glad you found a use for it!
              • renderizaR
                renderiza
                1.0.6 Beta:: 4/19/2013
                * Plugin is portable friendly now
                This update makes the plugin portable for people that don't use the default plugins folder.
                Thanks to thomthom for suggesting doing this. πŸ‘
                • CadFatherC
                  CadFather
                  Thanks Renderiza - a great plugin.
                  1 question, is there anyway to avoid stacking objects on top of each other when free painting?
                  • renderizaR
                    renderiza
                    The closes thing to address this is "Don't Add:: If pointer on top of face" check-mark but its suggested that the axis of the object is being use to pain is centered. Problem with the method I mentioned is that it only works if you are painting on empty surface and you might still have some staking here and there.
                    I am still thinking to add a feature that solves this issue but until l then you might want to look at this...
                    On http://sdmitch.blogspot.com/ there is a plugin called Component Check - Check for over-lap of given component removes one.
                    Here is Direct link and video link...
                    https://docs.google.com/file/d/0Bw8zdmaKDWIfNjgxYjAzNmYtNjQ0YS00ZTkwLThlYTMtNTMwZTFmNWZhZDJh/edit?pli=1
                    Page Not Found
                    Web word processing, presentations and spreadsheets
                    (docs.google.com)
                    Cheers! πŸ‘
                    • CadFatherC
                      CadFather
                      I see.. well it is quite amazing already - one of those 'unleash the creative' plugin (and thanks for the links). πŸ‘
                      • renderizaR
                        renderiza
                        Canvas v1.0.8 Released!
                        Hi, this is small update to make plugin compatible with Extension Warehouse.
                          matt.gordon320
                          Hey Renderiza, great plugin so far, I'm excited to see what you come up with next!
                          Just wanted to give you a head's up that there's a little typo (components is misspelled) that shows up in the Status bar when you hover over the Canvas Icon.
                          • KrisidiousK
                            Krisidious
                            Nice work Rafael...
                            By: Kristoff Rand
                            • renderizaR
                              renderiza
                              Thank you!...that typo will be fixed for next version of Canvas. πŸ‘
                              @krisidious said:
                              Nice work Rafael...
                              Thank you very much! πŸ‘
                              • renderizaR
                                renderiza
                                [pre:1th8ey5v]Authors:: Renderiza
                                Plugin Name:: Canvas
                                Version:: 1.9
                                Date:: 8/4/2013
                                Cost:: Free[/pre:1th8ey5v]
                                New Canvas Release!
                                %(#909090)[What is New!
                                • Random Rotation
                                • Random Scale]
                                  ______________________________________________________________________
                                Web-Dialog
                                http://s13.postimg.org/dpwiv3kp3/canvas_1.jpg
                                • EdsonE
                                  Edson
                                  it would be great to have a short video – like the ones Rich produces – to show all the plugin's funcionalities.
                                  I am afraid it just does not work for me on mac. I tried selecting some components, not selecting, different input points, etc. nothing happens.
                                  could anyone explain the correct workflow to make this plugin work?
                                  http://www.mahfuz.arq.br
                                  • renderizaR
                                    renderiza
                                    [pre:3o2qehfz]Authors:: Renderiza
                                    Version:: 1.1.0
                                    Date:: 9/25/2013
                                    Cost:: Free[/pre:3o2qehfz]
                                    Canvas v1.1.0 is now available for download.
                                    %(#909090)[What is new:
                                    • Smaller interface
                                    • Tons of Bug fixes]
                                    • renderizaR
                                      renderiza
                                      [pre:1okaqzi0]Authors:: Renderiza
                                      Version:: 1.1.1
                                      Date:: 9/27/2013
                                      Cost:: Free[/pre:1okaqzi0]
                                      Canvas v1.1.1 is now available for download.
                                      • Bug fixes!]
                                      • halroachH
                                        halroach
                                        @krisidious said:
                                        what is the difference between this and spray paint can?
                                        It looks very similar to Component Spray. So what are the differences?
                                        404 Not Found
                                        (sketchucation.com)
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                        • renderizaR
                                          renderiza
                                          404 Not Found
                                          (sketchucation.com)
                                          There are couple differences but I guess the most significant is how each plugin choose to apply the objects. You can paint a single object at a time by left clicking with both plugins, but when it comes to applying multiple entities each extension have their unique ways of doing so.
                                          Canvas will spray multiple objects by clicking & holding the left mouse button so that when you move around it will paint.
                                          Component Spray has different shapes like line,triangle,square, ect. so the user draws with that shape and multiple object will spray according to that.
                                          Both support random scale & rotate feature and each of them have different type of filters for applying object.
                                          Note: I am currently working on Canvas for improving its web-dialog so keep an eye for future update
                                          • renderizaR
                                            renderiza
                                            [pre:101ascxl]Authors:: Renderiza
                                            Version:: 1.1.3
                                            Date:: 10/12/2013
                                            Cost:: Free[/pre:101ascxl]
                                            Canvas v1.1.3 is now available for download.
                                            • 3 / 5
