    Across country dark evening
    21 Posts 11 Posters 1.4k Views 11 Watching
      davidh
      An old model relocated to a different environment.I wanted to get the feel of a dark evening lit only by a very low sun with a slightly ominous feel from the clouds
        jpalm32
        Great sky. Is it HDR or PP?
          davidh
          Its a combination of 2 skies done in photoshop,one bright(you can see the blue just by the moon) the other dark clouds.
          I also used the dodge tool in photoshop to increase the highlights on the right and behind the building.The foreground was darkened to help accentuate the brightness of the middle ground.
            davidh
            A much more colourful version with different sky and foreground.Again the sunlight highlights on the middleground grass was burned in using the dodge tool in photoshop .
              Romantic! β˜€
              • olisheaO Offline
                olishea
                Loving the second one, yes its romantic πŸ‘
                oli
                • ken28875K Offline
                  ken28875
                  Beautiful render, David. Love the mood. πŸ‘
                  _KN
                  Follow Your Dreams.
                    davidh
                    A night shot called "moonlight and torchlight".The light in the building is a lens flare and the light falling across the grass in the foreground is done using the dodge tool again,to suggest someone off to the right pointing a light.
                    I use the dodge tool all the time even in daylight shots to add highlights or accentuate bright areas.
                    • N Offline
                      nickchun
                      Beautiful. Thanks for the tip about the dodge tool, very effective in the right hands. Is the little flock of birds becoming your trademark?
                      • olisheaO Offline
                        olishea
                        Looks like car headlights, as if the final person is leaving to go home πŸ‘ Just fantastic!
                        oli
                          davidh
                          Heres one from way off,the building is just visible on the middle far right.The sky is the same as the one in the second last image but augmented to add some blue and darkened at the right hand side.
                          • RichardR Offline
                            Richard
                            FREAK! πŸ˜†
                            Mate the second one is AWESOME!!! You have an amazing knack of capturing a "mood"!
                            BUILTBRAND.COM.AU
                              davidh
                              Thanks Rich!Although in the last one and these 2 its almost a case of "Wheres Wally" trying to spot the building!
                                wow!
                                  davidh
                                  The obligitory night shot with some additional red/yellow lights added towards the horizon to try and bring some colour into the otherwise cold image.
                                    davidh
                                    Another sunset version.
                                    No matter what model I make or render,I always end up returning to low evening sun which can create very strong contrasts and highlights,such as on the tall grass at the foreground.
                                    Its definetly my favourite type of light to use and experiment with.
                                      Hi David, your ARTwork is fantastic as always. A true artist, thanks for once again brightening my day and making sketchup woes vanish, for a while at least. You should be making a fortune from these.....
                                      I copy them and use them in my architectural renders (I hope you do not mind) from time to time, they are not used for commercial purposes but they are a great addition to a picture frame for living rooms walls etc.
                                      Truly marvelous work Sir.
                                      • olisheaO Offline
                                        olishea
                                        gallery stuff!! πŸ˜„
                                        oli
                                          davidh
                                          Thanks a lot for the compliments guys!
                                          Check out my blog where I upload images done in similar stlyes to those posted here,along with my version of digital watercolours.There are currently 223 images posted.
                                          http://dhrenders.blogspot.ie/
                                          • ely862meE Offline
                                            ely862me
                                            Are you human ?
                                            Wonderful !
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 1 / 2
