    Across country dark evening
    21 Posts 11 Posters 2.0k Views 11 Watching
    • olisheaO
      olishea
      Loving the second one, yes its romantic πŸ‘
      oli
      • ken28875K
        ken28875
        Beautiful render, David. Love the mood. πŸ‘
        _KN
        Follow Your Dreams.
          davidh
          A night shot called "moonlight and torchlight".The light in the building is a lens flare and the light falling across the grass in the foreground is done using the dodge tool again,to suggest someone off to the right pointing a light.
          I use the dodge tool all the time even in daylight shots to add highlights or accentuate bright areas.
          • N
            nickchun
            Beautiful. Thanks for the tip about the dodge tool, very effective in the right hands. Is the little flock of birds becoming your trademark?
            • olisheaO
              olishea
              Looks like car headlights, as if the final person is leaving to go home πŸ‘ Just fantastic!
              oli
                davidh
                Heres one from way off,the building is just visible on the middle far right.The sky is the same as the one in the second last image but augmented to add some blue and darkened at the right hand side.
                • RichardR
                  Richard
                  FREAK! πŸ˜†
                  Mate the second one is AWESOME!!! You have an amazing knack of capturing a "mood"!
                  BUILTBRAND.COM.AU
                    davidh
                    Thanks Rich!Although in the last one and these 2 its almost a case of "Wheres Wally" trying to spot the building!
                      wow!
                        davidh
                        The obligitory night shot with some additional red/yellow lights added towards the horizon to try and bring some colour into the otherwise cold image.
                          davidh
                          Another sunset version.
                          No matter what model I make or render,I always end up returning to low evening sun which can create very strong contrasts and highlights,such as on the tall grass at the foreground.
                          Its definetly my favourite type of light to use and experiment with.
                            Hi David, your ARTwork is fantastic as always. A true artist, thanks for once again brightening my day and making sketchup woes vanish, for a while at least. You should be making a fortune from these.....
                            I copy them and use them in my architectural renders (I hope you do not mind) from time to time, they are not used for commercial purposes but they are a great addition to a picture frame for living rooms walls etc.
                            Truly marvelous work Sir.
                            • olisheaO
                              olishea
                              gallery stuff!! πŸ˜„
                              oli
                                davidh
                                Thanks a lot for the compliments guys!
                                Check out my blog where I upload images done in similar stlyes to those posted here,along with my version of digital watercolours.There are currently 223 images posted.
                                http://dhrenders.blogspot.ie/
                                • ely862meE
                                  ely862me
                                  Are you human ?
                                  Wonderful !
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                    Macker
                                    These are nothing short of absolutely stunning. Keep up the good work!
                                    Check out my blog @ http://macviz.blogspot.co.uk
