    Across country dark evening
    21 Posts 11 Posters 2.0k Views 11 Watching
    • ken28875K
      ken28875
      Beautiful render, David. Love the mood. πŸ‘
      _KN
      Follow Your Dreams.
        davidh
        A night shot called "moonlight and torchlight".The light in the building is a lens flare and the light falling across the grass in the foreground is done using the dodge tool again,to suggest someone off to the right pointing a light.
        I use the dodge tool all the time even in daylight shots to add highlights or accentuate bright areas.
        • N
          nickchun
          Beautiful. Thanks for the tip about the dodge tool, very effective in the right hands. Is the little flock of birds becoming your trademark?
          • olisheaO
            olishea
            Looks like car headlights, as if the final person is leaving to go home πŸ‘ Just fantastic!
            oli
              davidh
              Heres one from way off,the building is just visible on the middle far right.The sky is the same as the one in the second last image but augmented to add some blue and darkened at the right hand side.
              • RichardR
                Richard
                FREAK! πŸ˜†
                Mate the second one is AWESOME!!! You have an amazing knack of capturing a "mood"!
                BUILTBRAND.COM.AU
                  davidh
                  Thanks Rich!Although in the last one and these 2 its almost a case of "Wheres Wally" trying to spot the building!
                    wow!
                      davidh
                      The obligitory night shot with some additional red/yellow lights added towards the horizon to try and bring some colour into the otherwise cold image.
                        davidh
                        Another sunset version.
                        No matter what model I make or render,I always end up returning to low evening sun which can create very strong contrasts and highlights,such as on the tall grass at the foreground.
                        Its definetly my favourite type of light to use and experiment with.
                          Hi David, your ARTwork is fantastic as always. A true artist, thanks for once again brightening my day and making sketchup woes vanish, for a while at least. You should be making a fortune from these.....
                          I copy them and use them in my architectural renders (I hope you do not mind) from time to time, they are not used for commercial purposes but they are a great addition to a picture frame for living rooms walls etc.
                          Truly marvelous work Sir.
                          • olisheaO
                            olishea
                            gallery stuff!! πŸ˜„
                            oli
                              davidh
                              Thanks a lot for the compliments guys!
                              Check out my blog where I upload images done in similar stlyes to those posted here,along with my version of digital watercolours.There are currently 223 images posted.
                              http://dhrenders.blogspot.ie/
                              • ely862meE
                                ely862me
                                Are you human ?
                                Wonderful !
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                  Macker
                                  These are nothing short of absolutely stunning. Keep up the good work!
                                  Check out my blog @ http://macviz.blogspot.co.uk
