Across country dark evening
Heres one from way off,the building is just visible on the middle far right.The sky is the same as the one in the second last image but augmented to add some blue and darkened at the right hand side.
FREAK!
Mate the second one is AWESOME!!! You have an amazing knack of capturing a "mood"!
Thanks Rich!Although in the last one and these 2 its almost a case of "Wheres Wally" trying to spot the building!
wow!
The obligitory night shot with some additional red/yellow lights added towards the horizon to try and bring some colour into the otherwise cold image.
Another sunset version.
No matter what model I make or render,I always end up returning to low evening sun which can create very strong contrasts and highlights,such as on the tall grass at the foreground.
Its definetly my favourite type of light to use and experiment with.
Hi David, your ARTwork is fantastic as always. A true artist, thanks for once again brightening my day and making sketchup woes vanish, for a while at least. You should be making a fortune from these.....
I copy them and use them in my architectural renders (I hope you do not mind) from time to time, they are not used for commercial purposes but they are a great addition to a picture frame for living rooms walls etc.
Truly marvelous work Sir.
gallery stuff!!
Thanks a lot for the compliments guys!
Check out my blog where I upload images done in similar stlyes to those posted here,along with my version of digital watercolours.There are currently 223 images posted.
http://dhrenders.blogspot.ie/ -
Are you human ?
Wonderful !
These are nothing short of absolutely stunning. Keep up the good work!
