Material Colors Disappeared
I assigned a lot of materials (just colors) to my model. While using orbit, for some reason, all the material colors become invisible. I cant get them back - tried restarting.
The entity info suggests the materials are still assigned to one face. I tried reversing faces to see it was on the inside. but its not.
Is there some way to show/hide material colors?
Alex -
Materials don't just 'disappear'.
Not unless you close the SKP without saving some changes...
I assume they are all still in the Model tab of the 'Material Browser'.Use the 'Styles' toolbar to change the View Mode.
The Shaded Mode will show colors only.
Shaded-with-Textures also shows any textures...
You might have picked one of the other Modes that ignores colors - like Monochrome [far right, which just shows default front/back materials, useful when re-orienting colored faces], or Hidden-Line which is 'black and white'...Alternatively check for any faces that are hidden [View > Hidden Geometry > ON] and also OFF layers...
Great - I must have changed the style by accident. Thanks
Register LoginAdvertisement
