    Faces All Reversed
    3 Posts 3 Posters 307 Views 3 Watching
    • R
      rh5000
      Hi All,
      First post here that I know of...been using SU for many many years, though.
      I think someone has to have asked this question before but I must be searching for the answer poorly.
      I have a model...not every model...that I am too far into to start over and somehow, every single face I create is backwards. I have to reverse every face. I can't figure out what I did that I am now somehow in an alternate universe inside my model.
      The only think I can think of that I did is I rotated the model (of a house) to be correctly oriented to the sun after importing a cad background. But I can't see how that would do it. I did not rotate the axis.
      Anyway, I've had this happen before but never on anything really important...
      It's not an insurmountable issue but just curious if someone knows what I did and/or if there is a cure.
      Thanks!
      Ron
      • TIGT
        When you create a face the order of adding the vertices dictates the face's orientation.
        Except if the face is on the ground, flat at z=0; then it always faces downwards irrespective of the direction cw/ccw of its vertices... This is because SketchUp assumes you will want to PushPull it upwards and leave a base face in place.
        The right-click context-menu 'Reverse' becomes available in the command list for making a Shortcut [under Preferences] if you have a face selected when first opening Preferences...
        It is highly recommended that you have a shortcut to 'Reverse', 'Orient' is also very handy...
        • KrisidiousK
          Krisidious
          Now that TIG has explained what is going on in your model... I would offer some tools to fix what has been done.
          TIG Fix Reversed Face Materials.
          http://sketchucation.com/forums/viewtopic.php?f=323&t=30107&hilit=reverse+faces+tool
          Fredo Tools (reverse face orient)
          http://sketchucation.com/forums/viewtopic.php?t=42089
          ThomThom UV Tool Kit
          http://sketchucation.com/forums/viewtopic.php?t=18992
          Thomthom Material Tools.
          http://sketchucation.com/forums/viewtopic.php?f=323&t=17587&start=90
          and there are others too...
          By: Kristoff Rand
