    Vray for sketchup toon material ( HELP )
    renderpluginsextensions
    11 Posts 5 Posters 3.8k Views 5 Watching
    • I Offline
      imabzeous
      Hello to all... I have just learn how to make vray toon material but my problem is that it does not render the line ( i also change thickness to 4 but still the same thing).. Can any body help me what i am missing? my vray version is 1.48.8
      • panixiaP Offline
        panixia
        i don't know anything about the toon material.. but i suggest anyway to update to vray 1.49.01
        • I Offline
          imabzeous
          Its not about version i think coz i saw a tutorial in which the author was using old version...
          • stefanqS Offline
            stefanq
            You need to let the render to finish.Toon material won't be visible during the GI calculation .
            • panixiaP Offline
              panixia
              i'm not saying that updating will solve this particular problem.. but i think is a good thing to have the program as up to date as possible.. πŸ˜‰
              • I Offline
                imabzeous
                here is the quick render with steel blue color having line weight of 4 and yellow is 8.. but still πŸ˜• its the same thing...
                plz help me
                Thank you
                • I Offline
                  imabzeous
                  i am trying and playing with different setting but its not working : i get the same thing
                  • ToboboT Offline
                    Tobobo
                    plz help me
                    Thank you
                    You need to make sure that you have painted the object with the toon mateial.
                    Select the whole cube and then use the bucket to paint. dont forget the toon material is based on another.
                    Toby
                    Philippians 4:13
                    • andybotA Offline
                      andybot
                      um, silly question, but are you trying to render a line in vray? If you are, you need to give it a face. Vray doesn't render lines, no matter what material you give it.
                      You could also share your test file and maybe the answer is in there.
                      • I Offline
                        imabzeous
                        I dont know what was problem but i restart my pc and make a new file and it work like a charm..
                        • I Offline
                          imabzeous
                          lol no i wasn't trying to render a line thats why i was using toon material πŸ˜›
