    Glass not rendering ( quick help )
    renderpluginsextensions
    5 Posts 3 Posters 499 Views 3 Watching
    • I Offline
      imabzeous
      Hello i need some urgent help if any body can help me plzzz.......
      i have a building façade made of glass and steel... when i view it in sketchup i can see through the glass but when i render it it reflects only and i cannot see inside the building.... i have use simple glass but its not working... its all reflection.. no matter what i use its reflection reflection.. i also used simple sketchup glass with no properties .but still i can not see the inside building.
      I am attaching the render image and a part of the façade as the original file is too heavy to be uploaded ..
      sample façade
      • I Offline
        imabzeous
        my vray version is... 1.48
          reymond
          it may be (without which I've now looked at) that you have to make the texture on both sides?
          Sketchup & Vray Trainer
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            In your sample file, the glass doesn't have any reflection layer when I open it. When I add one, the glass renders fine.
            • I Offline
              imabzeous
              thank you fro replies.. i find the problem.. it was in the refraction layer the color was black when i turned it white it was fine then 😄
              thank you
