    Display components as placeholder boxes?
    6 Posts 6 Posters 428 Views 6 Watching
      sebstck3
      Is it possible to do as in 3ds max and any other modelling program : to display complicated components as placeholder boxes?
      I m building a fence and i cant use a texture as I need to see its "3 dimensionality"... the file is tiny but impossible to work with because of display problems...
      Any help would (really!) appreciated
        TECHDAVE02
        Try Fredo6 GhostComp http://sketchucation.com/forums/viewtopic.php?t=21469#p180536
          Tyler
          Will this increase performance when working with complex scenes/models?
            Anything you do to reduce the amount of a information that gets pushed through the GPU will help keep performance up.
            • BoxB Offline
              Just in the interests of using native tools.
              It is possible to construct a model with many simple "box" components and then replace them with a complex component when you are ready.
              Easily done in the component window. select the instances and replace selection.
                Or you can have a set of simpler models (boxes) as components and more elaborate ones saved as skp files. Then either reload each manually when needed or use TIG's xref manager plugin.
