Display components as placeholder boxes?
Is it possible to do as in 3ds max and any other modelling program : to display complicated components as placeholder boxes?
I m building a fence and i cant use a texture as I need to see its "3 dimensionality"... the file is tiny but impossible to work with because of display problems...
Any help would (really!) appreciated
Try Fredo6 GhostComp http://sketchucation.com/forums/viewtopic.php?t=21469#p180536
Will this increase performance when working with complex scenes/models?
Anything you do to reduce the amount of a information that gets pushed through the GPU will help keep performance up.
Just in the interests of using native tools.
It is possible to construct a model with many simple "box" components and then replace them with a complex component when you are ready.
Easily done in the component window. select the instances and replace selection. -
Or you can have a set of simpler models (boxes) as components and more elaborate ones saved as skp files. Then either reload each manually when needed or use TIG's xref manager plugin.
