    Triangulation and Convex Polygons
    25 Posts 7 Posters 1.6k Views 7 Watching
    • gullfoG Offline
      gullfo
      @mrapsouthern said:
      http://dl.dropbox.com/u/22511393/tmp3.png
      does the SU-Catt converter then create the correct output?
      Glenn
      http://www.runnel.com
      • gullfoG Offline
        gullfo
        @mrapsouthern said:
        It is off topic - but I am very familiar with that work - it's quite a coincidence you posted it....
        i'm trying to re-work Jonathan's SU-ABEC to use ABEC 2.0 but it's tough because their model shifted a lot... http://www.jonsh.net/blog/?page_id=197
        Glenn
          mrapsouthern
          Glenn,
          Small world. I know Jonathan well also. Have we met?
          Anyway, Yes, if the faces with holes are partitioned as shown the output of SU2CATT is interpreted correctly.
          Cheers
          A.
            mac1
            Will merging vertices help?
            Your model reduced from 200+ to ~72
              mrapsouthern
              Merging vertices looks like it helps for that case. I can't check it for multiple holes though right now. Thanks
              • 2 / 2
