    Triangulation and Convex Polygons
    25 Posts 7 Posters 2.6k Views 7 Watching
      I was thinking one edge from inner to outer was enough - in order to reduce the number of faces.
      But thinking of it more, ultimately everything breaks down to triangles, so if you have a polygonal face in SU - internally it'll be made up of many triangles. The same thing goes for any other software. So converting a face into it's internal triangles doesn't really make the model heavier - in terms of total number of triangles the graphic card needs to draw.
        Better to make a retoplogy in 3D party ?
          mrapsouthern
          To update my previous post -
          Any 1 face with ANY number of holes can be divided into 2 faces with no holes.
          where the number of required dividing lines is defined by,
          NumDividingLines = NumHoles + 1
          please see the following diagram as illustration.
          http://dl.dropbox.com/u/22511393/tmp3.png
          Alex
          • gullfoG
            gullfo
            slightly off-topic:
            http://gamma.cs.unc.edu/propagation/main.pdf
            http://sketchucation.com/forums/viewtopic.php?t=36063
            Glenn
            http://www.runnel.com
              mrapsouthern
              @gullfo said:
              slightly off-topic:
              It is off topic - but I am very familiar with that work - it's quite a coincidence you posted it....
              • gullfoG
                gullfo
                does the SU-Catt converter then create the correct output?
                Glenn
                • gullfoG
                  gullfo
                  i'm trying to re-work Jonathan's SU-ABEC to use ABEC 2.0 but it's tough because their model shifted a lot... http://www.jonsh.net/blog/?page_id=197
                  Glenn
                    mrapsouthern
                    Glenn,
                    Small world. I know Jonathan well also. Have we met?
                    Anyway, Yes, if the faces with holes are partitioned as shown the output of SU2CATT is interpreted correctly.
                    Cheers
                    A.
                      mac1
                      Will merging vertices help?
                      Your model reduced from 200+ to ~72
                        mrapsouthern
                        Merging vertices looks like it helps for that case. I can't check it for multiple holes though right now. Thanks
                        • 2 / 2
