    Handle problem
    20 Posts 6 Posters 795 Views 6 Watching
    • tibetT Offline
      tibet
      hi,
      i´m trying to make this handle, but without success.
      could you please someone tell me, how to do it please?
      thanks in advance
      best regards
      SU 2015 Pro on Win10 x64
        Upload the image to the forum, please.
        • tibetT Offline
          tibet
          hi dave,
          thanks for your offer, the image´s been uploaded.
          i´ve done a little in SU, but the window´s been closed without any warning,
          and i lost my model (...damn!)
          do you know how to recover any lost model please???
          thanks!
          • ely862meE Offline
            ely862me
            I think he said about the image in your first post 😉 .
            Regarding your handle. Try to make a simple sheet then extrude it with Joint Push&Pull .
            Elisei (sketchupper)
            Come and See EliseiDesign
              Thanks for uploading the image here, George.
              Do you still have a question about how to draw the handle?
              As to recovering a file after closing SketchUp, unless you saved it, there's nothing you can do but start over.
              • tibetT Offline
                tibet
                hi, thanks for a tip.
                as i sais i did it with image.
                i´ve deleted the original image , and replace it with the recent one.
                any other tips are heartily welcome !!!
                well, the first stage is okey, but the handle is going narrow and round.
                that´s the problem.
                SU shut down without warning, i think i lost everything.
                • tibetT Offline
                  tibet
                  hi dave,
                  i´ve a backup setting every 5 minutes, but the latest file is empty. i´m really fu**ed.
                  anyway, any tip to make a nice handle would be great, thanks!
                  • gillesG Offline
                    gilles
                    FredoScale bend, for some reason did not work with Shape bender.
                    • tibetT Offline
                      tibet
                      hi gilles,
                      you must be a genius to make it so quick! thank you!
                      i can´t believe my eyes man! 😍
                      so, is it the first or second plugin you mentioned?
                      best of luck!
                      • gillesG Offline
                        gilles
                        Anybody will do it in the same time if he knows how to use the tool.
                        • tibetT Offline
                          tibet
                          hi,
                          you´ re right, but still it´s pretty cool!
                          back to my question, is it the first or the second? 😄
                          god bless your work!
                          • gillesG Offline
                            gilles
                            The first, the second should handle this to ( 🤣 ) but for some reason it does not.
                            Surely my fault.
                            • pbacotP Offline
                              Gilles suggested "Fredoscale Radial Bending". Also you may have more luck if you scale your handle up 10-100 times do your work then scale down, since SU plugins often can't create smaller faces, but large faces remain when scaled smaller.
                              Are you going to round edges off like the one in the picture?
                              For realism, I suggest you don't curl the end so much.
                              • tibetT Offline
                                tibet
                                Surely my fault.
                                hi,
                                thank for tips, you really give me a hope !
                                http://i717.photobucket.com/albums/ww173/prestonjjrtr/Smileys/winner.gif
                                do not hesitate to share anything you know, you surely make people happy !
                                best of luck to your work!
                                • tibetT Offline
                                  tibet
                                  hi,
                                  thanks for your valuable tip !
                                  at the end i´ve encountered a strange behaviour of su
                                  http://i427.photobucket.com/albums/pp355/stoker187/8d216d40b336e82ff9119d97ad2b51264b6.gif
                                  when i open a model / attached below, and i make a rectangular and import decal as
                                  texture/attached below too, to finish my work. then everything crashes !
                                  any idea please? thanks
                                  AutoSave_Untitled_3 (2).skp
                                  • tibetT Offline
                                    tibet
                                    I crashed importing as texture, and crashed several times, then tried importing as image and got what you have, but too big to import,...sorry
                                    hi vispa,
                                    thanks for valuable experiences !
                                    • V Offline
                                      Vicspa
                                      I crashed importing as texture, and crashed several times, then tried importing as image and got what you have.
                                      AutoSave_Untitled_3 (2)-2.skp
                                      • V Offline
                                        Vicspa
                                        I tried again tibet and it did import. Learning experience for both of us.
                                        • tibetT Offline
                                          tibet
                                          cool, i´m glad you made it.
                                          can´t believe it, such a small problem causes total crash of almost unbeatable SU 😳
                                          hope it may be fixed automatically in the future versions of SU.
                                          best of luck!
                                          **%(#4000FF)[anyway, the problem has been solved, and finally i did it.
                                          but i´d be glad to see your techniques and tricks to make it
                                          better, if you will be so kind to share it! Thanks]**
                                          • tibetT Offline
                                            tibet
                                            this is the final goal...
                                            it isn´t perfect at all, but with shared knowlege of this excellent forum is getting
                                            better and better every day!
