    Handle problem
    20 Posts 6 Posters 881 Views 6 Watching
    • tibetT
      tibet
      @dave r said:
      Upload the image to the forum, please.
      hi dave,
      thanks for your offer, the image´s been uploaded.
      i´ve done a little in SU, but the window´s been closed without any warning,
      and i lost my model (...damn!)
      do you know how to recover any lost model please???
      thanks!
      SU 2015 Pro on Win10 x64
      • ely862meE
        ely862me
        I think he said about the image in your first post 😉 .
        Regarding your handle. Try to make a simple sheet then extrude it with Joint Push&Pull .
        Elisei (sketchupper)
        Come and See EliseiDesign
          Thanks for uploading the image here, George.
          Do you still have a question about how to draw the handle?
          As to recovering a file after closing SketchUp, unless you saved it, there's nothing you can do but start over.
          • tibetT
            tibet
            hi, thanks for a tip.
            as i sais i did it with image.
            i´ve deleted the original image , and replace it with the recent one.
            any other tips are heartily welcome !!!
            well, the first stage is okey, but the handle is going narrow and round.
            that´s the problem.
            SU shut down without warning, i think i lost everything.
            • tibetT
              tibet
              hi dave,
              i´ve a backup setting every 5 minutes, but the latest file is empty. i´m really fu**ed.
              anyway, any tip to make a nice handle would be great, thanks!
              • gillesG
                gilles
                FredoScale bend, for some reason did not work with Shape bender.
                • tibetT
                  tibet
                  hi gilles,
                  you must be a genius to make it so quick! thank you!
                  i can´t believe my eyes man! 😍
                  so, is it the first or second plugin you mentioned?
                  best of luck!
                  • gillesG
                    gilles
                    Anybody will do it in the same time if he knows how to use the tool.
                    • tibetT
                      tibet
                      hi,
                      you´ re right, but still it´s pretty cool!
                      back to my question, is it the first or the second? 😄
                      god bless your work!
                      • gillesG
                        gilles
                        The first, the second should handle this to ( 🤣 ) but for some reason it does not.
                        Surely my fault.
                        • pbacotP
                          Gilles suggested "Fredoscale Radial Bending". Also you may have more luck if you scale your handle up 10-100 times do your work then scale down, since SU plugins often can't create smaller faces, but large faces remain when scaled smaller.
                          Are you going to round edges off like the one in the picture?
                          For realism, I suggest you don't curl the end so much.
                          • tibetT
                            tibet
                            Surely my fault.
                            hi,
                            thank for tips, you really give me a hope !
                            http://i717.photobucket.com/albums/ww173/prestonjjrtr/Smileys/winner.gif
                            do not hesitate to share anything you know, you surely make people happy !
                            best of luck to your work!
                            • tibetT
                              tibet
                              hi,
                              thanks for your valuable tip !
                              at the end i´ve encountered a strange behaviour of su
                              http://i427.photobucket.com/albums/pp355/stoker187/8d216d40b336e82ff9119d97ad2b51264b6.gif
                              when i open a model / attached below, and i make a rectangular and import decal as
                              texture/attached below too, to finish my work. then everything crashes !
                              any idea please? thanks
                              AutoSave_Untitled_3 (2).skp
                              • tibetT
                                tibet
                                I crashed importing as texture, and crashed several times, then tried importing as image and got what you have, but too big to import,...sorry
                                hi vispa,
                                thanks for valuable experiences !
                                • V
                                  Vicspa
                                  I crashed importing as texture, and crashed several times, then tried importing as image and got what you have.
                                  AutoSave_Untitled_3 (2)-2.skp
                                  • V
                                    Vicspa
                                    I tried again tibet and it did import. Learning experience for both of us.
                                    • tibetT
                                      tibet
                                      cool, i´m glad you made it.
                                      can´t believe it, such a small problem causes total crash of almost unbeatable SU 😳
                                      hope it may be fixed automatically in the future versions of SU.
                                      best of luck!
                                      **%(#4000FF)[anyway, the problem has been solved, and finally i did it.
                                      but i´d be glad to see your techniques and tricks to make it
                                      better, if you will be so kind to share it! Thanks]**
                                      • tibetT
                                        tibet
                                        this is the final goal...
                                        it isn´t perfect at all, but with shared knowlege of this excellent forum is getting
                                        better and better every day!
