    Print Preview ?
    5 Posts 4 Posters 311 Views 4 Watching
      danna
      When choosing print preview, I see my model as a speck, a couple of miles away.
      Not sure what I changed or how to fix.
      • Wo3DanW Offline
        Wo3Dan
        At least disable 'Use model extents'.
        Play with 'Fit to page' enabled and zoom in enough on your model.
        • BoxB Offline
          If zoom extents takes you to the same distance then you have a bit of geometry somewhere off in the distance.
          • N Offline
            nickchun
            Select all with Ctrl A and temporarily make a group. The blue bounding box would give you an idea as to the extends of the geometry.
              danna
              That worked, Thanks.
              @box and @nickchun
              Thanks for the tips.
