Print Preview ?
When choosing print preview, I see my model as a speck, a couple of miles away.
Not sure what I changed or how to fix.
At least disable 'Use model extents'.
Play with 'Fit to page' enabled and zoom in enough on your model. -
If zoom extents takes you to the same distance then you have a bit of geometry somewhere off in the distance.
Select all with Ctrl A and temporarily make a group. The blue bounding box would give you an idea as to the extends of the geometry.
