    Problem Creating a sphere... one circle disappears
    5 Posts 3 Posters 1.8k Views 3 Watching
      MarkEMark
      I have tried creating a sphere several times and am stumped.
      Process:
      Draw a 1" circle on the x Plane.
      Draw a .5" circle on the z plane, intersecting the centers of both circles, and 90 degrees to each other. Picture 1 below.
      Double click on the larger circle to select it with the selection tool
      Select the Follow Me Tool.
      Select the vertical circle face and the vertical circle DISAPPEARS. Picture 2.
      I have restarted the program in the event that there is a problem with the program. I have also successfully created a sphere earlier in the day on the same file.
      Any thoughts? Help! ๐Ÿ˜ฎ)
      Using the Free version of Sketchup 8.
      Mark
      Setting up the sphere process
      The moment I hit the mouse after selecting the follow me tool and then the smaller circle I wish to create the sphere from. Any ideas what's wrong?
        It's just too small. Try scaling things up by a factor of 100 and do it again.
        • Jean LemireJ Offline
          Jean Lemire
          Hi Mark, hi folks.
          See this SU file for ideas.
          Holes in sphere.skp
            MarkEMark
            @jean lemire said:
            Hi Mark, hi folks.
            Thank you! This was the first time I tried a .5" sphere, so I get why it might have been too small.
            I will try as you suggest!
            Many thanks!
            Mark
              MarkEMark
              It worked! Thanks!!
